Question about Toshiba Televison & Video
Tray won t open or close - Toshiba Televison & Video
4 Suggested Answers
gopakumarg43
  • 75581 Answers
SOURCE: tray won't close fully then pops open again what needs to be done.
Hello
Its loading mechanism has the fault. It must be replaced. Check its loading belt, before replacing the loader mechanism.
Picture of the loader mechanism is given here.
http://www.dataentryjobs.us/67948.html2_28_2012_4_54_10_am.jpg
Posted on Feb 28, 2012
ercupa190
  • 12223 Answers
SOURCE: Samsung dvd R155 disk tray won't open/eject
1) try to clean the button with special contact cleaner spray
2) if this work, is o.k otherwise use the r. control and try to open the tray if work, is obvious the button was dirty. If doesnot work, you must the DVD player.
3) inspect any belt and replace, and lube any shaft +gear with small lubricant( vaseline) and replace any parts broken.Tight any wires connector very well and clean it.
4) if doesnot resolve the problem you must go the repair shopt TV for fix it.
God bless you
Posted on Aug 01, 2012
SOURCE: the dvd tray on my Sony BDV-E780W won't stay closed. Whenever I turn it on the tray opens and wont close from the remote or device.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Posted on Dec 02, 2012
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
The dvd tray on my Sony BDV-E780W won't stay closed. Whenever I turn it on the tray opens and wont close from the remote or device.
Dec 01, 2012 | Televison & Video
Problem with the tray.it is not working properly and cant come out
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual
God bless you
Sep 27, 2012 | Philips DVP-3005 DVD Player
Problem with the dvd tray
God bless you
Sep 27, 2012 | Televison & Video
My 360 kinect won't read disks. It says open tray,
my x box 360 Kinect want work because when I put the game in it said open and close the tray
Apr 08, 2012 | Video Game Consoles & Games
Tray won't open
by just resetting the software will not work this is a mechanical problem this usually happens on players that is not use for a long time or improper closing of tray..fixing this kind of problem requires opening the cover of the unit..you need to lubricate all moving gears and parts by putting enough amount of lubricating oil..you have also need to assist the motor manually by helping it to push the tray out just gently pull the tray with your hands during a eject command on the unit clean also the limit switches of the tray make that contact are properly working..good luck!
Apr 06, 2012 | Kenwood DV-605 Multi-disc DVD Player
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Tray won't close fully then pops open again what needs to be done.
Hello
Feb 27, 2012 | Sony DVP-NC600 Multi-disc DVD Player
Ashtray in my 2005 Kia Amanti Stays open
It sounds like the spring mechanism on the tray is either bent or broken. You can try removing the tray and bending the spring steel to increase the friction or you may have to purchase new or used ash trays.
Nov 23, 2011 | 2005 Kia Amanti
Televison & Video Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
