Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
Hp pavilion dv200 Laptop, lights come on, no screen of HD activit
Lights come on, fan comes on, no monitor, no HD activity, no bios beeps, all hardware removed from the under compartment. Still nothing.
  • 1 more comment
  • winn090486 Apr 23, 2009
    ok memory is in and so is all hardware, i know that with desktops, if the memory is removed and than the computer is powered on, the bios will tell you with beeps. Maybe this does not apply to laptops. Let me repeat though. All power lights come on, the cpu fan does come on, but no screen and the hard drive is not running either. Its crazy.
  • Dick
    Dick May 11, 2010
    Suggesting that you power up your 120v machine with 220v power is simply begging to destroy EVERYTHING. Don't do it.
  • Dick
    Dick May 11, 2010
    If all hardware is removed from the under compartment the computer has no memory in it and will not function without it.
Iv also had the same problem..and it was the video chip on the mobo. i just heat it up real good and it had started to work again..
Posted on Jul 25, 2009
The fix for this is weird but works! make sure you have quite a lot of charge left in the battery , then turn it on close the lid and wrap it up in a duvet for about 45 minutes, it will not damage it but maake sure you dont go over an hour, what this does is reseal the video card in the machine as this is a known fault with these machines, i did it with my beloved DV6000 which was out of warranty, leave it to cool down and then turn it on hey presto! it will work again..yep i was very dubious aswell but trust me it works! and you;ve nothing to lose if its out of warranty as the fix is to replace the motherboard!
Posted on Jul 19, 2009
    Sergeant:
  • 329 Answers
Sounds like maybe bad hard drive or Ram problems, maybe even a mother board... Try this un plug power, on back of power supply is a small usually red switch in power supply that switches from 120 to 220 power. with power off turn to 220 side and turn on machine. Less than 5 seconds turn off and switch back to 120 volts. I have seen this work on several HP Pavillions.. Good Luck
Posted on Apr 23, 2009
    Problem Solver:
  • 12 Answers
Craigy2009 is right in that it is likely the video chip failing. These were recalled under the link at the bottom. Often you can get HP to take them back if you complain enough. If they don't though, i wouldnt recommend putting it in a towel or anything else. Send it to a shop that will do board level repairs. They can usually reflow/replace the video chip for around 150-175 dollars.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Laptop turns on but fan stop running
Does anything show up on the screen? What lights come on? Any beeps?
Feb 02, 2013 | HP Pavilion dv7-1132nr Notebook PC
I have hp pavilion dv2000, when I plug in dc cord it switches on without pressing power switch. Than I'm able to switch it off and on. All lights on panel and motherboard switch on also. CPU fan switches...
dv2000 zero support now at hp,
2006? year.
so does the VGA port on the rear of PC work. to a desktop monitor
yes, then the mobo is ok. but not screen.
easy no?
i can make the mobo run on a table. vga connected.
with Fn+F4 toggled on and external USB keyboard, I can activate the external screen.
steps. are as follows. in proper order
1: remove that shorted huge battery, there. get it out of there.
2: make sure the power pack reads (VM) 19vdc at the jack.
3: new coin cell if voltage on its pins below 2.9v... yah?
4: get BIOS screens working FIRST. disconnect HDD and DVD drive. now.
5: go to 1 ram stick bank 0 (try 2nd one by self)
6: does the flashlight trick work on that CCFL screen,?
7: remove all modules from MOBO cept CPU and 1 stick RAM?
we call that the strip down tests.\
8: beep codes, or Caps lock key flash codes? what?
BIOS screens have to work, or mobo is dead.
has anyone been playing with BIOS doing crazy things like flashing it.>? yes, oops now you bricked it. then what (ask)
if pc is 2008 that is the solderball from hell year.
see that and the CCFL test here.
http://www.pcdied.com/monitors.html#flashlighttest
Aug 16, 2017 | HP 417035-001 - HP Pavilion dv2000 Series...
Boot laptop with no memory installed should give seris of beeps to clear memory,next remove battery install mem if it boots ok battery hanging up laptop if not plug in mem one at a time to see if one is bad.
Jan 11, 2011 | HP 417035-001 - HP Pavilion dv2000 Series...
Power comes on but no beeps lights or monitor
burnt up your motherboard. You will have to replace it
May 27, 2010 | Compaq Presario CQ60-220US PC Laptop
Desktop will not boot into bios No Usb power;monitor ''No Signal''
Your problem is the memory . YOu have to put off the pc and remove the memory card in the slot. Then clean the silver pins in your memory with a rubber eraser. Put it back and see if the BIOS will be prompted on the screen , if not you have to replace the memory.
Feb 12, 2010 | Acer Aspire T160 (AST160UA3400) PC Desktop
HP ZE2000 blank screen on start up.
you need to change the lcd inverter card of your note book
Oct 21, 2009 | HP Pavilion ze2000 Notebook
SCREEN WENT WHITE
Pity you... take the laptop to HP service. you may need to replace the mainboard.
Try plug in a monitor to it, press together the Fn key and the one that have a monitor like icon in different color. If normal screen comes up, you are in luck - only the screen's cable to the main board is at fault.
If really nothing happen at all (no hard disk activity, no CPU fan), then replace the mainboard or get a new one.
I hope you are not using the laptop on a cloth covered table so that the air intake is blocked. this is how some connectors on the main board melts the soldering so that it's cut off (extreme hard to see by eyes).
Mar 20, 2009 | HP Pavilion dv9000z Notebook
After 2 hours of continous work, my hp pavilion dv9500 just looses image and than after30 seconds it frezes the other programs who were still running on my vista ultimate After restart shut down etc I dont...
Its a notebook.
step 1: remove the main battery , run now on the line pack?
step 2 is BIOS screens if they are dead, then the screen is dead.
DV95000 has CCFL back lamps that fail, most this old have.
do the fish light trick next
the bios key is F10, it prompts you every time you turn it on
so if it stops prompting, you lost power, or the screen is dead
BIOS works even with the HDD removed.
does the fan blow , battery out, and power pack plugged in to wall ac power?
does it beep (sounds) or flash Caps lock keys? if yes those are codes. (Morse like codes)
what does this mean,?
"I can still see that my lcd lights up."
you mean LED,s'
get bios working,
first.
Aug 22, 2017 | HP Computers & Internet
Laptop wont turn on
Are there any noises like its attempting to start up? Any beeping, fans running? If there are and the activitity lights are flashing, but just the monitor is off, than I would definatly say there is probably a bad connection between the motherboard, and monitor.
Aug 23, 2007 | Compaq Armada M700 Notebook
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
4,393 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
