The CD player on our Sharp CD-DH790 unit no longer works. When we put in any disk it does not read and reports "No disk"
  • 44 Answers
SOURCE: CD-R Playback Issue
Have the same problem with one of the cd-players in my home. A technics cd-player. Some fo the home-burned cd's work now and then. Sometimes it plays them, sometimes not.
Posted on Jul 07, 2009
Grubhead
  • 5056 Answers
SOURCE: My stereo won't read the disks inserted in my CD player
All you can do is get a lens cleaner and hope that clears it up, otherwise you are looking at what might be an expensive replacement of the CD/lens/laser unit.
Posted on Dec 22, 2009
  • 979 Answers
SOURCE: My 5 Disk CD player doesn't work. It wont read any
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Posted on Aug 19, 2010
aviral_srms
  • 1216 Answers
SOURCE: cd player no longer works
    • 1 Remove excess dust from the CD player. Dust is the number one enemy of electronics, and it can corrode even the most resilient device. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
    • 2 Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
    • 3 Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
Posted on Jul 31, 2011
  • 6771 Answers
SOURCE: sharp cd xp 120 CD play button does not work.
The pad switch"hidden under the button" is more than likely the issue.
Posted on Mar 17, 2012
Testimonial: "I figured out it goes right to a circuit board that has the buttons on it, the board itself needs to be replaced. Now just have to find one."
Car radio cd player error 43
The motor that spins the disk no longer works, disassemble the cd player and replace your cd motor with a new one. Radio shack has them, but I suggest replacing your player with an aftermarket unit like sony, kenwood, audiovox, or any other high quality cd players.
Dec 07, 2013 | Hyundai Cars & Trucks
Doesn't recognize disks anymore
i would try lens cleaning cd 1st ok might be dirty lens just cant read it if not that try firmware update to the unit thx nick
Feb 04, 2008 | Lite On LVW-5005 DVD Recorder
Sharp cd xp 120 CD play button does not work.
Mar 16, 2012 | Sharp CD-XP120 CD Shelf System
Put blue ray disk in my sharp bdhp21 blue ray
Could be one of three problems.
1 - The disk is in upside down. Try turning it over.
2 - The disk is bad. Take it back to where you purchased it and get a refund / exchange.
3 - The BR player is faulty. If you have played disks in this unit before, try another disk and see if it will play. If THAT disk plays, see #2 above. If it doesn't, and you get the same error, then the unit needs technical servicing.
Jan 05, 2010 | Sharp BD-HP21U Blu-Ray Player
CMT-EH10 CD player does not recognize any disks
try a cleaning if that does not work then if the unit has been dropped laser could have been knocked out of alignment or has reached the end of it's lifetime. You didn't tell me how old the unit was I've had CD players
that only lasted as little as 11 months and the reader go bad. anyway try the cleaning first and if that don't work
I would look for another unit.
Nov 28, 2009 | Televison & Video
Will not read dics
If you go to sharp global web site, choose your country then go to downloads to download update, can be done for cd or usb stick, if you use cd version can burn to disk using nero 9 which is availble as free trail on net. then put disk in player and it will update on own. should correct problem
Jan 25, 2009 | Sharp AQUOS Blu-ray Disc Player
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
No recognize disks CD and formats MP3
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if the player will no longer read any commercial cd that you attempt to play or MP3 disks, the unit is defective and needs to be replaced. The unit has a 90 day warranty from the date of purchase. You will need the receipt in order to receive a warranty exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 01, 2008 | Coby DVD-224 DVD Player
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
Xl-hp515
wait a bit... it will happen with all the other decks, too. we had this happen and the first time the suggestion from the Sharp folks worked. We left the unit unplugged overnight to reset the electronics (and of course all the station presets, etc.) now, we have it happening again and all 5 drawers are out. the "read TOC" then report "no disk". i will try the lens cleaner but if that doesn't work, we will take it to a repair shop. our unit is actually almost 3 years old so it is past the extended two year warranty, but still it is too soon for it to be acting up. i hate cheaply made stuff like this! good luck.
Apr 12, 2007 | Sharp XL-HP515 CD Shelf System
 Grubhead
Grubhead
