Question about Konica Minolta DiALTA Di200 Copier
My copier will not stay on - i turn it on and within seconds it
Turns itself off - no error code is displayed - touch screen remains bland.
  • sam gerban
    sam gerban May 11, 2010
    what is the code?????
  • Konica Minolta Master
  • 6,696 Answers
Checked your power saver in the user choice
Posted on May 09, 2009
How to reset error code d370 on konika minolta c450 machine
1. Touch the following code on the trouble code display screen.
(buton) Stop 0 7 1 3 9
2. [*] will be displayed on the trouble code screen.
3. Touch [*].
4. The screen will be shifted to the data restoration screen to perform data restoration.
NOTE
• When the restoration is performed in a short time, data restoration screen may not
be displayed.5. Check the message which indicates that the data restoration was successfully conducted.
Turn Main power OFF, and wait for ten seconds or more to turn it back ON
GOOD LUCK
Jan 12, 2015 | Minolta Office Equipment & Supplies
Whenever I switch on to start operating, during my waiting to warm up, it displays error code C-D369. and it doesn't function from there.
Error code reset:turn OFF the copier ,press and hold the Utility key to right hand,to left hand turn ON the copier,wait appaire on the display Trouble reset,touch the screen and turn OFF the copier.Wait 2 minute and turn ON.
Jan 17, 2013 | Konica Minolta bizhub C250 All-In-One...
Code 3452 and my touch screen is not working
These could be related problems, however I doubt that they are. The error code 3452 refers to thermistor not reaching temp within specified 30 second time frame. There is a sensor there that monitors this. Touch screen may not work due to error code. However, I'm a little suspect that it may be a different problem. But first, let's solve the initial issue and then move onto the screen.
Try clearing the error code first, and then if it appears again, you'll need to look at replacing either the sensor or thermistor. If you are not a certified technician, but attempting to resolve yourself, I would suggest sending the fuser back to whomever you purchased it from and telling them to supply you with another one. During rebuild they probably did not properly gauge the sensor from the fusing roller. therefore it is not able to properly monitor temperature. (very common problem)....
Here is the instructions for clearing the error code:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while holding down the Utility/Counter key more than 10 seconds after. A screen will appear saying "TROUBLE RESET"
3. Touch "TROUBLE RESET".
4. Check to make sure that "OK" is displayed below which confirms it has been reset.
If "OK" is not there , it will show a different code....
IF it says "OK", you should be good to go. Error code should now be cleared.
5. Just Turn off the Main Power Switch wait at least 10 seconds....and turn it on. Make sure that the machine properly starts.
** If it re-displays the code again within a short period of time, replace the fuser unit. Or get a certified technician to replace the or adjust the sensor or Thermistor unit. However, since you just purchased this I will assume that it is either a defective unit from manufacturer, or the company who rebuilt it did not properly ensure it was working. Return it and demand a replacement in EITHER case!! J
Hope this helps
Sep 02, 2011 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizhub c350 c-0500 display
Fuser warm up failure. Most likely this will require a service person to repair but here is the reset procedure you can try yourself. If it does not reset then you will need a service technician.
Turn off the main power switch located on the right side of the copier, NOT the one on the edge of the operation panel. Press and HOLD the utility/counter button on the control panel. While holding this button down continuosly turn on the main power switch. Continue holding the utility counter button until the screen changes to a blank screen with just a box that says "trouble reset". Now release the utility/counter button and touch the trouble reset box. Now turn off the main power switch for a few seconds then turn the machine back on. The code should be gone but if a problem remians then the code will come back within 30 seconds.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Konica Minolta DiALTA Di200 Copier
My HTC touch pro has some backlight problem or maybe hardware. When I press the power button the backlight turns on and turns off itself within a split second. and when i leave it to charge. the...
If the resett has not helped to confirm the error to be software related or not it will be good to have it checked on an HTC service centre for a code error. It will then be confirmed if this is a hardware issue.
Get estimate and decide, get warranty if it is within the period.
Sep 29, 2010 | HTC Touch Pro Smartphone
When I turn on the machine (bizhub c300) error code c3452 appears, within 20 secs, How do I reset this code
This is a fuser related code.
To reset the code, please do the following
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch Trouble Reset.
4. Check to make sure that OK is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Good luck
Jan 21, 2010 | Konica Minolta Bizhub C300 All-In-One...
C-D370 error code for Copier KONICA-MINOLTA C252
this has to do with what they call NAVRAM IS C
To troubleshoot the error:
1. Reset the code by pressing stop-0-7-1-3-9. This will display a "*" on the LCD. Press this button.
2. Perform a Data Clear and then perform the Setup Procedures from the beginning.
3. Perform a NVRAM Recovery Procedure. Please see attached document. To view the PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for free from RRUPTED/need to be reset BUT that will clear all the current setting especially if print to it.if you are willing to try ....
you should have a Tech do this...
good luck
Sep 17, 2009 | Office Equipment & Supplies
Sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
May 22, 2009 | Ricoh Aficio CL7200 Laser Printer
Aficio 1035
Not sure what SC818 is as not in my manuals please try the following.
Entering and Exiting SP mode
1. Press the Clear Mode key.
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
Once in the service mode turn the main switch off located on the left hand side of the machine wait 5-10 seconds then switch back on. This should get the machine working. Hope this helps
PLEASE DO NOT ADJUST ANYTHING ELSE WITHIN SERVICE MODE AS CAN DAMAGE MACHINE OPERATION)
Thanks J
Dec 24, 2007 | Ricoh Aficio 1035 Copier
Konica Minolta DiALTA Di200 Copier Logo
70 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
