Question about Dryers
Trying to get in back of dryer to check fuse
How do I get into the back of a kenmore Electric dryer model 86983810 to check the fuse. My dryer got hot and then died.
  • rherd May 04, 2009
    Thanks,
    I got it fixed and replaced the fuse.
  • 77 Answers
Unplug the dryer first. Then you will see many 5/16 screws that need to be taken out. Once you've done that, should come right off. Good luck
Posted on Apr 23, 2009
Kenmore 240 volt compact electric dryer not heating model # 110.89182990
U need to check the heating element ,u know how are CALl for service
Mar 13, 2015 | Kenmore Dryers
How do l change thermal fuse on Kenmore dryer model 110.88752793
Hello Shelton;
My name is Peter. I am a retired field service appliance technician.
25439664-j5jtgwve0qxm0uckbdimcx40-1-0.jpg Thermal fuse 3399849 trips if the exhaust air leaving the dryer becomes too hot.
Unplug the dryer before installing the thermal fuse. Wear work gloves to protect your hands during this repair.
This Dryer Thermal Fuse part #3399849
This is located in the back of your dryer on your hot air exhaust manifold.
Feb 17, 2015 | Kenmore Dryers
My dryer is not blowing hot air the brand is kenmore model # m-460-g
Check the element and fuses for continuety
Replace as needed.
Jun 06, 2010 | Kenmore 62602 Electric Dryer
Dryer doesn't "dry"... eletrician/husband inspected the unit- circuits working for heating element. Belt intact. Dryer tumbles, but doesn't get HOT. Thermostat?
It depends on if the unit is electric or gas. Both will have a thermal fuse if the venting is restricted the fuse will blow if its a whirlpool or kenmore brand. The thermal fuse is white and will be either located on the back or in the front by the blower housing. If the lint screen is located in the top the fuse will be in the back. Have your husband take a look at the schematic he should be able to find the fuse. Also i know he probalby checked this but the unit needs 240v for the unit to heat if its electric but the motor will still run with 120v. Make and model would allow me to help much more.
Jan 11, 2010 | Estate TEDS840JQ Electric Dryer
Re: Kenmore dryer 110 86983810.
unplug dryer, no take off bottom panel,use a screw driver or putty knife to remove,there are to clips on top of cover around 2 inches from edge,you'll feel them with tool,push in on them and clips will release, take out lint filter and take off blower wheel duct.clean out lint from duct,now on top of the blower wheel housing you'll see the thermal fuse,part number 3390719,take off one of the wires and read it out with meter,if it's bad change it out,if it's good,pull a wire off of heater and check that and read out the t-stats if you want but i would just change out the part that is bad.also vac out the dryer and go outside and make sure air is blowing flapper open,iblow the vent line out with a leaf blower if it's a long run,you won't believe all the stuff that blows out of there,hope this helps you
Nov 28, 2009 | Kenmore Dryers
Kenmore dryer model 110 86983810. I need to replace the thermal fuse. How do I take off the back cover. I removed all the screws, separated the top panel; but it does not just slide off.
The back panel is not removeable. The entireshell must be removed - exposing the rear of the machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 28, 2009 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Dryer stopped working as it was drying, was real hot and will not start now. Kenmore 80 series electric
Problem common with blocked vent, need to check house vent...dryer has blown the thermal fuse. found behind the back panel small white fuse(usual two blue wires)....clear the vent and replaced the fuse. run on air dry first to check vent, should feel close to a hair dryer on low.
Jun 10, 2009 | Kenmore Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore Heating Element
There are levels of heat according to cycle and some driers do not use all the coils during low heat cycles. They rarely need replace unless visably broken. There could be a loose connection.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Dryer works no heat not breaker
hi!! you must always check for voltage first. If you have 120 volts and 220 present then its you thermal fuse that is bad.its a small white oval fuse located near the dryer blower replace that and you should be fine..Good luck..
Jan 03, 2009 | Dryers
Dryers Logo
197 people viewed this question
Top Dryers Experts
