Question about Optics
Tasco 37ZBC Spotting Scope
When I pull the rear lens back it comes off. I think it's missing a screw. Can you please help? Thanks, Jim
SOURCE:
  • 274 Answers
SOURCE: RA11 A Spotting scope
I did a little research for you. Check your manual but I think your "eye piece" has a 12.5mm thread into the body of the scope. The FSA-L1 has a 15.2mm thread which goes in the place of and replaces the eye piece for the models it fits. Check that manual too. If you have calipers you can verify it too by measuring the male thread of each. What you need if you can find it is a 12.5mm (male) to 15.2mm (female)adapter. Becareful it doesn't change the focal length. Check with photo shops or on-line. I'll do a quick search too and repost if I find one.
Posted on Jul 16, 2007
informatica
  • 1114 Answers
SOURCE: SWIFT MARK II, MODEL 841 SPOTTING SCOPE BASE
Hi, I would contact Swift directly on this number: For ordering parts or warranty repair information, please contact Swift Customer Service at 800-523-4544. You can get other contact information and dealer locations on their website: http://www.swift-optics.com/support/faq/dealer The 'scope is mounted on a standard camera tripod thread so you can always check your local camera dealer. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2007
  • 4 Answers
SOURCE: what lens do i insert into scope to view the moon
The moon is big so use the 25mm. The Barlow will have a multiplication marking on it 2x 3x etc. A 2x Barlow lens will effectively double the power of the eyepiece you are using. Do not use the erecting eyepiece for anything other than land viewing. Erecting eyepieces generally reduce the amount of light reaching your eye and thus reduce brightness of the faint objects in the sky.
So basically just place the 25 mm lens in the focuser and point the scope at the moon and you will be amazed at what you can see and how bright it is.
Posted on Jan 02, 2008
cammedic
  • 667 Answers
SOURCE: Bausch & Lomb 60mm Spotting scope focus screw
Try here: Eagle Optics
2120 W. Greenview Dr.
Middleton, WI 53562
Posted on Jan 25, 2008
  • 5 Answers
SOURCE: tasco scope manual
The manual is here under "Generic Riflescopes". It is a .pdf file.
http://www.tasco.com/support.cfm
The Tasco site for Riflescopes
http://www.tasco.com/section.cfm?s=Riflescopes
Posted on Jul 19, 2008
What is the ideal spotting scope Lens Size?
You simply need to choose if you prefer a better image quality or a smaller and lighter spotting scope. A spotting scope with a larger lens (60mm to 100mm) will have better light-gathering capability than a smaller 50mm lens spotting scope. This means that the image you see will be brighter and clearer. You will also enjoy a wider field of view. On the other hand the bigger the lens is, the larger and heavier your spotting scope will be. Larger spotting scopes are also more expensive.
Think about where you will be using the spotting scope the most. If you normally stay at a fixed location for a long period or don't need to worry about extra weight then opt for an 80mm to 100mm scope (if you can afford it of course). If you like to travel light or move around more than a 50mm to 60mm scope will suit you better. Some 50mm scopes can even be used without a tripod when needed.
May 27, 2018 | The Optics
How open golden antler scope?
Instruction Manuals ' Tasco® - Believe it.
www.tasco.com/pages/instruction-manuals/
Golf Scopes; Infocus - 514FMY ... QP22 Electronic Open Reflex Sight · ProPoint Red Dot Scopes · Tasco Generic Riflescopes (6 Languages) · Vital Zone Reticle ...
bout 236,000 results (0.65 seconds) Search ResultsTasco Golden Antler 3 - (9 x 40 mm) Repair Questions ...www.fixya.com/.../p4821-tasco_golden_antler_3_9_x_40_mm_3_9x40Recent Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm) questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Spotting Scopes.Tasco Scope Problem [Archive] - Cast Boolitscastboolits.gunloads.com > ... > Cast BoolitsAug 1, 2009 - 12 posts - ‎10 authorsErgo, if you have a Tasco or Redfield optic that needs repair, use your ... Have a couple of "golden antler" Tasco scopes a rep gave me back in ...Tasco Golden Antler Riflescope - YouTube
Jan 24, 2016 | Tasco Golden Antler 3 - (9 x 40 mm)...
Need a manual for a tasco nv 200 scope
they are a general manual for spotting scope
http://www.tasco.com/products/manuals/spottingscope_general.pdf
Is important to people who share knowledge, rate points and hear your comments. Is the answer is helpful give points
Sep 18, 2011 | Tasco Optics
Where to find tasco 3 x 9 40 rubber armored scope
I have an original Tasco rubber armored sope that I bought over 20 years ago. It is Japanese made very good quality comes with the special rings made just for it. It also has lens covers as well. I will it go for $40 dollars. you can reach me at [email protected]. Thanks, Dennis.
Nov 13, 2010 | Tasco Golden Antler 3 - (9 x 40 mm)...
Loose internal lens
I would call bushnell at 800-423-3537 option 2 they are the ones that produced this.
Mar 16, 2009 | Optics
Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Jan 16, 2009 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Sep 22, 2008 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Tasco scope manual
Feb 01, 2008 | Tasco Golden Antler 3 - (9 x 40 mm)...
Optics Logo
143 people viewed this question
Top Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
