Question about Generac Electrical Supplies
Can not find serial or model #'s nissan 1.2L LPG 20 kw looking for operating pressure on outlet side to carb 3-6 wc?
3 Suggested Answers
SOURCE: Model No. 040234, Serial No.
This is absolutely not a gas psi problem. You haven't mentioned if the unit was connected to load or not. That FC5 fault is low frequency and could very well be caused by an overload condition. Take an amperage reading while the problem is occurring. If it is not overloaded then it seems like you may have a problem with your governor control circuit assuming the engine is running ok otherwise. Some basic checks include checking mag p/u voltage (they are generally located directly over the flywheel on aircooled engines and are difficult to see so try to following wiring) while cranking / running generally it should be over 1.5 vdc. Also check for mechanical binding. If the unit never makes 60 hz. also try adjusting the govenor although If the unit did make good frequency at some point you may be having a problem with the controller. If the unit is hunting dramatically then try adjusting whats called your frequency or governor gain setting to a point that's stable.
Posted on Jul 10, 2011
  • 7 Answers
SOURCE: Need a manual for honeywell generator model 6054 lpg
Can you please identify the problem you have with the 6054 generator. I may be able to assist.
Posted on Nov 23, 2011
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
Nov 12, 2011 | Electrical Supplies
Burner presure of pitco 45c lpg you said free
This information is generally stamped on the data plate. I believe it is 10" WC manifold pressure. 12" WC is required for the supply pressure with all other equipment on the line on. Hope this helps. All service and install manuals are available on www.pitco.com
Jun 18, 2011 | Pitco Frialator 45C Deep Fryer
Hi im a plumber/gas fitter who has been asked if i can convert a wildcat 410 (a2) ser 1983 from lpg to ng which is currently in use at a crash repair spray booth is this possible?
Yes look up the gas valve part # and find the LP kit for that model number. It will come with new pilot orifice, new burner orifices and the springs to replace inside the gas valve. Remember that natural gas is .08"wc and LP is a heavier gas it needs to be set at 11"wc .You need a manometer to check the pressure before you light it again .Did you know that propane provides more energy per unit volume than natural gas. Heat is measured in BTUs, or British Thermal Units. Propane provides about 2500 BTUs for the same volume of natural gas that only gives 1000 BTUs.
Nov 22, 2010 | Heating & Cooling
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Feb 27, 2017 | Char-Broil Commercial Stainless Steel...
Ford focus 1800 lx 2001 lpg
You will need to look on the tag on the tank its near the service valve should be riveted to service valve/ fuel gauge cover.the tag/plate will have retest date,model,serial number and important to you is whats known as water capacity,WC .what ever the water capacity figure is minus about12 litres and that is the lpg capacity.You could run it very close to empty and see how much it takes to fill it up.
Oct 10, 2008 | 2001 Ford Focus
Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Jan 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Electrical Supplies Logo
29 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
