Question about Ricoh Aficio 450 Copier
Copies have black streaks now
I have a Ricoh Aficio 1013 copier.
It has always worked perfectly, until we moved 35 miles.
Now, the copies have black streaks the length of the copies.
Where and what to clean?
The toner is nearly out, could this be an issue?
Like I said, it worked fine until the move.
  • Jim Keysor May 11, 2010
    Sounds like toner spilled on the target glass or up in the machine. One thing to clean on this model is the glass and make sure you clean the small what is called **** glass length of machine about 1 inch wide. Do the lines appear with the documet feed and the on the glass. If only with document feeder this small **** glass is dirty.
Dirt on the narrow glass will cause streaks through the Auto feeder, but copies should be clean if using the main contact glass if that's the case. Dirt/toner anywhere else (ie:laser optics) would cause light areas on the copies- not dark. Did this happen the very first time you used it, or shortly after? In other words, could it be coincidental? It sounds more to me, like the PCU (photoconductor/drum unit) needs replacement, or a fuser roller.
If cleaning the glass doesn't help, then one of these 2 things is causing your problem.
Posted on Apr 24, 2009
Where is exposure lamp on aficio 1013?
The exposure lamp is the lamp that lights up when you copy something which is located under the scanner glass. It is on the carriage that moves from side to side when copying from the glass.
Jul 15, 2014 | Ricoh Aficio 1013 All-In-One Laser Printer
What causes black streak lines on the entire copy
open the right door and look at the drum, lines on it? If not, its the hot section/fuser. -Carl
Jun 26, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Streaks in the first copy through adf
clean the narrow glass on left of where you place the copy on glass, remove if needed to clean both sides
Mar 16, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Ricoh Aficio 1013 error code sc 544
Fusing low temperature error
Symptom: Detected fusing temperature
remained abnormally low for 1
second during fusing operation
(below 140°C) or during standby
mode
Possible Cause: Fusing thermistor defective
• PSU defective
• Bad connection between fuser and
machine
Dec 18, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Apr 10, 2009 | Ricoh Aficio 1013F Copier
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 450 Copier Logo
334 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
