Question about Powerwasher 2400psi 2.0gpm Pw2420 Gas Powered Pressure Washer 4
Leaking gas from carburator - Powerwasher 2400psi 2.0gpm Pw2420 Gas Powered Pressure Washer 4
I have a 94 quadrunner that is busting up when you give it gas
is it fuel injected or carburated? if it is carburated look for leaks in and around the carburator it is usually the gasket between the carb and the manifild.
If is is fuel injected check the fuel you may have water in your tank. Also check the fuel in the tank of the carborated vehicle as well.
Nov 10, 2016 | Cars & Trucks
Steelcraft generator 3300 watt Gas tank shut off
The floater of the carburator is bad(Needle). its leaking gas at the carburator and the gas is coming inside the engine at piston intake valves.
Replace carburator needle that stops the intake of gas at the Carburator.
Sep 02, 2014 | Electrical Supplies
Why does my carburator leak gas?
You probably need to replace it.... :-(
May 13, 2014 | 1981 Yamaha XS 400
Outboard troubleshooting. I have a 75 hp Mercury with 2 carbuerators. Serial # 6559142 it's around a 1989 model.. Problem= tank bubble pumps up tight...sits for a minute and gets soft...when I pump it up...
Sounds like the fuel pump isn't working, you can buy service kits though quite often corrosion will prevent you from removing the valves.. or it could simply be the fuel cap isn't venting, remove fuel cap and see if the engine continues to run!
Mar 18, 2017 | Boating
Carburator leaks gas when cycle is started or running from what looks like vent hose?
Sounds to me like your float valve is obstructed by some debris. This is causing it to stay open and leak fuel. Better it leaks to your vent hose than it leaks in your engine and contaminates your oil.
You need a proper carb cleaning. Not some run in the gas tank sh*t. If the tank wasn't full when parked, chances are there is rust in the fuel system to get this out you need to disassemble the carburetor and thoroughly clean it.
Try not to ride the bike til you do this. It's a fire hazard.
Oct 08, 2012 | 2005 Honda VT 600 C Shadow
Makita dpc7311 leaks at crank
The DPC7311 is a two-stroke demolition saw, there should be no standing fluids, oil or otherwise in the crank case to leak out. The reason it uses a 50-to-1 gas-to-oil mix is so the oil in the gas can settle on the moving parts and lubricate them.
If you do have anything leaking anywhere out of your crankcase you most likely have problems with your carburator in that too much fuel is getting into and filling up the crankcase.
You should also look to make sure your leak isn't coming from a crack in the fuel tank or from the carburator or fuel line and running down to look like it's coming from the crankcase.
Feb 06, 2012 | Makita Saws
Troy-bilt bronco leaks gas from the air filter hopusing. How can i fix this?
Leaking gas through the air filter ports can only mean excessive gas flow from the carburator. Try adjusting the flow screws on the carburator bowl. Check all gaskets, seals, etc. and happy tilling!
May 06, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
89 ford f 150 4.9
Spray starting fluid near the carburator if equipped. It may be a leaking main gasket under the carb.If you spray and the engine turns off. It is a vacuum leak. meaning the main gasket under the carburator .
Jan 22, 2009 | 1993 Ford F150 SuperCab
Powerwasher 2400psi 2.0gpm Pw2420 Gas Powered Pressure Washer 4 Logo
Top Powerwasher Garden Experts
ray012965
Bill Boyd
jeff chenault
jeff chenault
Are you a Powerwasher Garden Expert? Answer questions, earn points and help others
