Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Dishwasher Kenmore Ultrawash
The dishwasher does not seem to go through the wash cycle. No water is wishing around. It does fill up with water and heat up but I never hear it washing. It gets very hot inside and after a long time finishes and drains but never washes.
  • Poot Sep 28, 2007
    I don't see the solution...Am I not looking in the right place??? HELP
One possibility is that the screen/filter to the wash units have become totally clogged. (I had this problem because of some particularly dirty water in the dishwasher.) To access the screen requires taking out the cover at the base of the dishwasher arm assemble which can be done without removing the machine, although you'll need a special screw spline screw driver. Given this the repair takes jsut five or ten minutes. Remove the screen clean it out in the sink and replace.
Posted on Feb 10, 2008
Kenmore Elite dishwasher takes water and discharges it, but will not start washing.
You must have a control panel problem, nothing else I know of causes this.
Sep 21, 2016 | Kenmore Washing Machines
My dishwasher seems to be stuck in washing mode. how do I troubleshoot?
the schematic behind the lower panel below door should have paper in clear bag with how to get codes.
May 13, 2014 | Kenmore 24" Built-In Dishwasher with...
My dishwasher fills with water and then 45 second to a minute when the dishwasher is in the washing cycle the sprayer stops spray or washing the dishes and it seem that the water has drained out of washer...
Have you confirmed the water has drained out, or is the water just too cold, so the heater coil is on to get water temp up. What happens if you just leave it alone? Does it continue through the cycle?
Jan 28, 2018 | Kenmore 17702 / 17709 Free-Standing...
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher not spraying/pumping water in wash cycle
If your dishwasher is filling, draining and the heating element is working then the wash pump motor has probably failed.
You have not provided the manufacturer and model number, so I have no way of knowing if your dishwasher has a separate drain and wash pump motor.
May 03, 2009 | Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
It fills, but doesn't kick in to spray/wash
Main pump not running?...then it will either be the program controller or the main pump itself.....I would guess the pump first.
Jul 17, 2007 | Kenmore 15522 Built-in Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
421 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
