Question about Health & Beauty
Err 1 message mean produex scale
Replaced batteries now have err 1 message in my model PEV-165E bathroom scale. any ideas?
SOURCE: Error message ErrL
My scale had the same problem.  I replaced the battery, but still got the same message.  My wife noticed that one of the feet on the bottom of the scale was loose.  The feet are twisted on to the scale and held by two small flanges.  When I gently pulled the loose foot away I noticed that a small black wire had broke.  I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together.  I then hide the wires back in a recessed area on the foot and placed it back on the scale.  Worked just like the day I got it.   Hope this helps!
Posted on Feb 20, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
  • 39 Answers
SOURCE: I have a Taylor body fat analyzer and scale model
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Posted on Jan 21, 2010
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of ThinnerĀ® Bathroom Scales
www.conairscales.com/catalog.php?product_id=428&ib=en
Scales for the way you liveĀ® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ...
www.livestrong.com > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. Healthometer.com: FAQs; "Health o meter User Manual" .
Jan 05, 2016 | Health & Beauty
Why do I just get an ERR message when I try to weigh myself?
The replacement batteries could be of the wrong type, defective, or incorrectly installed.
Oct 02, 2015 | Conair WW60 Weightwatchers Scale
After changing battery, why does err appear and not a 0?
The replacement battery could be defective or installed incorrectly.
Sep 05, 2015 | Salter 9037 - Digital Bathroom Scales /...
Instruction manual for a camry bathroom scales need to reset to kg
I have a Camry Personal weight scale, model EB9872 and am getting a message, "ERR". How can I fix this situation? Are there any manuals or customer service for the company?
Thank you for any suggestions.
Barbara
Nov 01, 2011 | Health & Beauty
My Salter bathroom scales (model 929) are showing an ERR message. They seem to think everything weighs more than it does as if u press gently on them the weight goes up really quickly until limit reached...
The best day chessboard type is the traditional type of weight, in contrast, electronic weight scale error degreehighestelectronic
tems, affected by environments, bumps can make reading deviation.The use of electronic weight meter can more precisely?
Electronic scales are generally placed in the hard flat floor use, not on the carpet or other soft object surface by using.Each weight to body weight in the same place, the same time, wear the same clothes.
Hello, I just see a online stores
http://www.tmart.com/Digital-Scales/ sell digital scales. Some advice, for reference purposes only and finally I wish you luck!
Jul 25, 2011 | Salter Health & Beauty
I HAVE A SET OF EKS ELECTRONIC BATHROOM SCALES AND ON REPLACING THE BATTERY I AM GETTING A READING OF ERR 5 WHICH I PRESUME IS AN ERROR CODE. CAN ANYONE HELP PLEASE?
When you see the err message step off the scale and wait 5-10 secs then step back on and it should be ok. Remember that when standing on it you must keep absolutely STILL.
Good Luck
Aug 14, 2010 | Health & Beauty
Hi. I have a Produex glass bathroom scale. I have no idea what model it is and I can't find the instruction manual. Somehow it got switched from pounds to kilograms and I don't know how to switch it back....
I have a produex glass scale that is silver with a solid black stripe on one side and rows of poka dots on the other side. It has a tiny swicth on the back that changes the scale from pounds to kilograms.
Jul 27, 2010 | Health & Beauty
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
Jan 15, 2010 | Health & Beauty
HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Oct 03, 2009 | Dmm Elscale Healthsmart Glass Electronic...
display the Error.
REMOVE YOUR FOOT.
Regards,
Linda DLT
Consumer Relations
& Salter Housewares
866-843-3905
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Health & Beauty Logo
48 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
