Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
X-box 360 Wireless Adapter
I swear I have done everything. I have hooked it up. It has detected my network, i put the code in even the back of the adapter is steady green, but as soon as I go in to test the connection it says that it cannot identify and IP address. I manually put in an address myself but it did not work either. the connection is working great for my laptop, it is running on the same network. I even put my USB into the computer then back in the x-box, then back to the computer, then it tells me that I have connected nothing to the network. I swear I have tried it all! Am I missing something? Please help!
  • night_fire_a Apr 23, 2009
    If by Encrypted you mean it has an WEP code, then yes, I have put that in though then it says connected
  • Adam Mcbride May 11, 2010
    Are you using encrypted wireless?
    Problem Solver:
  • 17 Answers
Ok the only thing i can suggest from here then is take the WEP key off your wireless and see if you can connect to it that way
Posted on Apr 24, 2009
I have installed it onto my computer and done everything the manual says and I have the USB model WNA3100. On the box it says that it is capable of connecting to consoles to support multiplayer gaming. I...
In order to do that you would have to plug this into your xbox 360, not your computer. HOWEVER, Microsoft only supports their own wireless adapter for the xbox 360 .... this one: http://www.amazon.com/Xbox-360-Wireless-Network-Adapter-Networks/dp/B000B6MLV4
I have also heard that wireless gaming can have lesser results. But if you want to do Xbox Live wireless, you will have to have a router and Microsoft's XBOX wifi adapter shown in the link above.
To connect to Xbox live, your best bet is to (if you dont have one) get a router, connect it to your Internet modem, and plug it into the xbox 360 using an ethernet cable.
Mar 08, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Can't get my wireless adapter to get connected to then wireless network
Hello
Go to your pc and get on internet explorer.Type 192.168.1.1 in the address bar.Hit enter
Username is admin
Password is password or admin
Once in get the wireless code or wep code and write it down.
Start x box,Go to network settings or wireless settings and put the wep code into the x box.
This should get you going.
Jan 08, 2011 | Microsoft Wireless Network Adapter Xbox...
My Microsoft Xbox 360 Wireless Network Adapter stopped working.
Shut off your console and unplug everything.
Connect the adapter then connect the console back together...Turn on console......Go to network configuration...Make sure u are connecting the adapter from the back!
If you are not able to achieve a connection for several attempts this means your should check warranty status for the adapter also.........If you unplugged it while the console was one you could of shocked the cable an blew the fuse.......Normally when u detach any components with a usb port u should alway make sure every thing is shut off before so.
www.xbox.com/support
Jan 14, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Jan 05, 2010 | 2wire HomePortal 1800HG Router...
What are the steps to hooking up your xbox 360 wireless network adapter
Hello
Plug the wireless USB adapter into the USB port on the back of the Xbox 360 console.
Turn on your Xbox 360 console.
The console will recognize the wireless adapter and will walk you thru the wireless network setup. Be sure to have your WEP key (if encryption is used) for your router before you start this process.
This adapter works well - I am using one and regularly play Modern Warfare 2 with multiple chat sessions. There is no noticable difference between my wired network connection and this wireless network connection.
Happy gaming!
Dec 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless 360 Network Adapter won't turn red
This can actually happen quit a bit but it sounds to me like the usb jack may be dieing or not producing enough power. This can be caused if for instance you use wired controllers. Have you tried using the front usb ports.
Oct 12, 2009 | Microsoft Wireless Network Adapter Xbox...
My light stays red never turns green
This means that it hasnt connected to a wireless router. Make sure your router is wireless, that you have searched for you network and found it. If this still doesnt work then make sure that your routers wireless capabilities are working and try entering the settings in manually to the xbox 360 network settings.
Jan 17, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless adapter lights up green but does not connect live
i had to change my ip address and so forth from manual to automatic because all the xbox needed to do was find everything by itself so that it could actually connect to my wireless network.
Dec 07, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless adapter not connecting 2 pc
u need a wireless router linsky is about the best out there
Sep 20, 2008 | Microsoft Wireless Network Adapter Xbox...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
244 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
