Question about Samsung WF337AA Front Load Washer
Burning smell in samsung WF218ANW/XAA front loader
SOURCE: mildew smell in front loader
Yup! I have the same issue with a WE206BNW (Canadian model). Did the same thing - dried the water off the door and leave the door open when not using it. Sort of helped, but then I ran an empty light load with bleach through it - no clothes, just water. Helped a lot.
Henkfish
Posted on Jun 08, 2009
kvhappliance
  • 218 Answers
SOURCE: WF218ANW/XAA not accepting cold water, only hot?
Hi you most likely have a bad water fill valve.
part # "dc62-30314k"
This is a common failure on all washing machines.
If I can be of further assistance please let me know.
Posted on Mar 18, 2010
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Posted on Jan 22, 2011
rickyrt441
  • 4399 Answers
SOURCE: i have a samsung front
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. This noise is heard in the spin cycle.
Posted on May 07, 2011
  • 2006 Answers
SOURCE: I have a Samsung Front
The first thing I would check is that the unit has been leveled. Adjust the washer feet until the unit is level. NOTE: Check the feet and make sure they are operational before starting a level procedure.
Posted on Jun 08, 2011
No power to washer, can't open the washer door
http://www.appliancepartspros.com/parts-for-samsung-wf218anw-xaa-0000.html Look at the video section to see how to get under that machine and open the door and drain it.
Oct 04, 2015 | Samsung WF218AN Front Load Washer
I was Samsung washing machine model number WF218ANW/XAA It's making a flapping sound in the back during a spin cycle.
unplug and re-plug the Washer and check if the issue persists. otherwise click on this link for chat support http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=346139&modelname=WF218ANW&modelcode=WF218ANW%2FXAA&session_id=QBLGXKdDpFv5J32LF2rR81JCHqnryJpb6V1ldwQh6Wt1RQfLhRQy%211780044318%211589942691%211354844292695&from_osc=#
Dec 06, 2012 | Washing Machines
Samsung front loader model number WF218anw/xaa stopped after load finished and power is off. No lights. Door won't open. Circuit breaker okay. Socket okay. Is there a circit breaker assessable to...
Well unplug and hope that powers down your solenoid that is keeping it closed. Whats happening is that it thinks there is still water in there and it doesnt want you opening it. So if there is no water in there turn off circuit breaker off then back on or unplug for a moment to see if it resets itself. It should open on power down and if nothing else clear itself on reboot (yes there is a computer in there) . I would say you have a faulty sensor or the sensor is staying wet some how . try those and let me know
Jun 23, 2011 | Washing Machines
My Samsung WF218ANW/XAA front load washer will not drain & the display reads "nd". I have already drained the water through the front panel tube & have cleaned that filter, washer still...
Jan 22, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
How do I replace the oring gasket on a front loading samsung wash machine model number wf219anw/xaa
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
Aug 11, 2010 | Samsung WF337AA Front Load Washer
Mar 18, 2010 | Samsung Washing Machines
There is water left in the detergent tray after the wash is over
This seems to be normal for ALL front loaders
I just leave mine open along with the front door to dry out
Nov 06, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Pre wash cycle- do y need to use every wash, what does it do
no check out the manual. the pre-wash is more for stubben dirt then delicates
May 12, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Need to take case off dryer there is something stuck inside because kids dried with lint screen out
SOMETHING IN THE BLOWER WHEEL CAUSING A OBSTRUCTION AND MOTOR WILL NOT START. START AT THE TOP THEN FRONT WILL COME OFF
Apr 29, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Samsung WF337AA Front Load Washer Logo
89 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
