Question about Denon DN-C635
Tray Error Message
Every time I insert a CD into the Denon compact disc / MP3 Player DN-C635 I get a 'Tray Error' message. If I open the tray, rotate the CD, and close the tray, the machine reads it properly. Why am I getting this "Tray Error" message and how do I fix this?
  • 165 Answers
SOURCE: faulty eject tray
hello you have a dirty switch on erratic use clean or change it
this switch is usually under the main drawer saludos
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Posted on Aug 03, 2009
SOURCE: CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Posted on Dec 04, 2009
bhatgiri73
  • 106 Answers
SOURCE: Hi. My denon dn s3500 just says disc error when I
clean the lens...if it does not work replace the lens.
Posted on Jan 24, 2010
supernova278
  • 1932 Answers
SOURCE: I have a Denon compact disc digital audio
There will be a fuse in the circuit board which is meant only for the operation of the motor.That is very small and looks like a resistor only.you need a specialist to replace that.one wrong thing will short circuit the board fully.
If you need a service guide you can download from below website
http://www.user-manuals.com/dn1800f-p-497121.html
Thank You
Posted on Jan 04, 2011
How do I adjust the dwell time of the cd tray? My DENON DN-1800F cd tray closes immediately after it opens.
You would have to open up the player. The tray is controlled by a single motor. It's possible that the alignment went off if the tray got stuck or pushed manually. Since the player uses a laser, make sure you do not plug it in while opening the player. If you don't feel comfortable opening it up, have someone repair it for you. Also be aware that opening the player could void any warranty when opening up any devices. If you still have warranty on the device use that first, also if you bought it with a credit card, check if you have any extended warranty through them. It's one of those perks easily forgotten.
Jan 08, 2015 | Denon Audio Players & Recorders
Denon DN-C635 CD Player problem.
In working with consumer electronics a lot of years, the pickup, mechanism or CD section is not always at fault but people that
are trying to work on their own equipment make assumptions that may not be correct. If you put in a new CD player then the other issues as with all wave soldered equipment can be bad solder joints and even bad solder at joints where the connectors are as these get a lot of activity in a repair. Look at the PCB well. I have fixed a lot of equipment by resoldering bad or broken joints. Check around power transistors and those larger drive transistors for these broken joints.
Mar 22, 2013 | Denon DN-C635 CD Player
Replacing laser assembly/mechanism on Denon DN-C635 CD player.
Don't usually have to do any alignment when replacing the pickup.
Mar 13, 2013 | Denon DN-C635 CD Player
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
Have a Denon DN-C635 CD player . Replaced motor spindle / laser assembly (plug and play part assembly from Denon $45 old price $151) It loads disc , voice coil moves laser lens up and down but spindle...
Dave, Holding the motor spindle / laser assembly in a position where the white ribben plug in receptacle is facing in an upward position, look down to the lower left hand corner of the print board just under the plug in. You will see a small blob of solder bridging two contact points. Remove this solder bridge. I have found two new Denon assemblys with this problem.........*****
Mar 11, 2011 | Denon DN-C635 CD Player
I get disc error when inserting a disc into my Denon DN S700
Are you using the correct format of discs? It requires Standard compact disc (12 cm), types CD-TEXT, CD-R, CD-RW (CD-R and CD-RW disks must be finalised before using - but even then will not always be accepted) It will not work with CD+R or CD+RW
If it will not work with ANY CD (including professionally produced CDs) then the lens may need cleaning. Purchase a CD cleaning disk (a computer CD cleaning disk will work fine) pop it in the slot and hit the play button.
You can download the manual here http://www.denondj.com/Assets/Dimages/Products/Manuals/ab8715a8c0d742f0ab8c9afed5bf90e0.pdf?ts=012725
Feb 08, 2011 | Denon DJ DN-S700 Compact Tabletop CD/MP3...
I have a denon 3500 cd player my cd is stuck
Open the top cover of your CD using a screw driver, (usually a star screw driver),. Then, manually turn the driving gear of the CD tray to free the stucked tray and until to the point where you can take the disc from the tray. Be careful so the setting of the tray and the laser eye is not change. Then, close the close the cover and play. You can send your e-mail thru fix ya to let me know.
Sep 25, 2009 | Sony CDP-C910 10-Disc CD Changer
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
TOC ERROR ON DENON DN-C615
Take this info with a grain of salt. I recently received one of these units with a TOC error, and after removing the drive assembly and reinstalling it, the problem went away. Before removal, I observed the motor spinning poorly and even backwards. Rather than pull the whole drive assembly, I would first eject the drive and remove the face from the tray. This is done by putting your thumbs on the tray and pulling up with your pointer fingers underneath the face. It should just snap off and snap back on the same way. Try playing a disc now, if it works try loosening the screws on the drive assembly and shifting the assembly towards the front of the unit, tighten the screws and put the face back on. You should be good to go. There are four screws holding the assembly down, the two in the back can only be accessed when the tray is in the open position. The front two are accessible through holes in the tray, and I don't recall if the tray has to be open or not, but that's easily observable. If it's still not working, there is a flat-flex cable running to the laser assembly. Pull and reseat this gently. Try to only manipulate the cable by the blue reinforcement tab. I hope this helps!
Aug 26, 2008 | Denon DN-C615 CD Player
171 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
