My abit kt7araid motherboard is shutting down for no reason. I recently installed two memory cards( ultra 512mb pc 133mhz.) I have an Anthon processor socket A.
  • Dick
    Dick May 11, 2010
    Was it shutting down before you installed those memory cards? If not, you need to take the cards out. Not all memory cards work in all motherboards. Sometimes they seem to work okay and cause seemingly random problems. Try some different cards.
  • 123 Answers
Test the memory, maybe a bad stick if this has just started happening
http://www.memtest86.com/
Posted on Apr 23, 2009
I have a ABIT KT7A Motherboard AMD2000+ Win98SE
Since it "runs fine with a 128 & 256", install those and go to a website called crucial.com. Study their opening page and let their website look at your system to see what it accepts. This is a fine company to buy memory from, AND it will ALSO tell you what your computer can be populated with. I've also seen weird things happen when your CMOS (coin battery) gets low. They're cheap, change it as a precaution.
Oct 25, 2013 | Abit KT7A Motherboard
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
I had 2 x 512mb memory installed with no problems. I recently installed 2 x 1Gb but the bios does not recognise it. The pc always hangs on boot up just before loading windows. The pc will work with the 2 x...
Hello gphillips397!
Abit has released an updated BIOS for the IC7-MAX3 motherboard which fixes quite a few issues with your motherboard including one that can cause the system to hang with certain memory modules. The updated BIOS is HERE and instructions for the upgrade are in Appendix G of the User Manual or a general guide is HERE
Nov 22, 2010 | Abit IC7-MAX3 Motherboard
I have 512 sd ram but i another 128,128 sd ram do included but its not working how can i solves this problem
The D815EEA2 motherboard only supports 512MB RAM maximum - I'm afraid there is no way to add more to it.
From Intel's description of the model:
Intel 815 Memory: Three 133MHz SDRAM DIMM sockets. Supports a maximum 512MB of 133MHz SDRAM
Aug 10, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
This motherboard is limited to 512Mb memory - is there a way to upgrade to allow more? ABIT-ST6
Sorry but this type of old motherboard has a limitation of having a 512MB of RAM as the maximum so there will be no way of upgrading it to a higher RAM, the best option that you can do is to change the motherboard to a new one....
Jul 31, 2009 | Abit ST6 Motherboard
ATI Radeon X1650 Pro overheats and videocard shuts down
check if the games take too much memory so that the card not able to work, if you used to play it before without problem, check the card fan if its working,and at the same time check your computer cooling if its cool enough.
Jun 14, 2009 | ATI RADEON X1650 Graphic Card
E machine T1150 wont start up
Make sure you have the memory installed correctly. Those beep codes identify it as bad memory. Try the old RAM.
Good luck with this.
Mar 19, 2009 | E-Machines T6420 PC Desktop
Ram upgrade problems IBM netvista 6794
You can try this site, it scans your system to see if your computer can run more memory than what is currently installed. it helps you find the right memory modules for your system and and an option for you to read reviews if available and if you want to buy it.
try this site: www.crucial.com
Please rate this solution
Dec 26, 2008 | IBM NetVista PC Desktop
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
Alarm sounds on PC when using FS2004
Does this alarm go off while playing Flight Simulator 2004?
Please include your operating system Ex: Win XP home, PRo . How much memory is in your system? How many dimms, 1,2,3,4?
What video card do you use, Ex: PCIE ATI Radeon 256Mb 9500?
Can you describe the alarm a bit better. A long beep with short beep, repeating untill the system shuts off?
Answer these question so I can narrow down the what may be troubling your Pc.
Feb 16, 2008 | Abit KN8 Ultra Motherboard
Computers & Internet Logo
David Payne
David Payne
