Question about Kitchen Appliances - Others
Need to know how to fill crofton steam cleaner item #4294-10
3 Suggested Answers
SOURCE: I don't know how to
Customer Service @ Euro-Pro tlod me to push it down and turn it. Thanks for the brilliant suggestion. After I told them I had done that they said I would have to send it in for repair. $25 + $12.95 S&H.
Posted on Jan 26, 2009
SOURCE: just purchased crofton sm 102
I had the same problem. Seems the little gizmo in the base that pushes up the water release valve is set a bit too low. With the water tank removed, you'll see a plastic circle with a plastic "x" in the middle. A tiny drop of glue on the "x" to raise the level a bit did the trick for me.
Posted on May 01, 2011
I need to know how much water to put in it.
press the helpful button
Fill the provided measurement cup to the maximum fill line with water. In areas with a high mineral concentration in the tap water, we recommend using distilled or demineralized water to prolong the life of the steam cleaner. Using the funnel, pour the contents of the cup into the reservoir.
Top Innovations, Inc.
400 NW Platte Valley Drive
Riverside, Missouri 64150
www.mitcoproducts.com
1-800-711-6617
http://steamerstore.com/steamfast/manuals/SF-250_Manual.doc
Jan 28, 2016 | Steam Fast SF-250 Mouse Vacuum
I have a scunci ss 1000 hand held steamer cleaner. Its been used and given to me from a friend. The steam comes out the trouble is the steam is not hot, just luke warm. how can I fix it myself.
Try descaling it with CLR. Add CLR and water, turn it on but not fully to produce steam, just get it hot. Leave it for an hour. Empty that out and out some more in. Get this up to steam for 10 minutes, switch off, leave it for an hour and empty it. Fill and rinse out twice. Fill with water and see if it is fixed.
Nov 09, 2015 | Scunci SS1000 Handheld Steam Cleaner
Quest Steam 9 in 1. How do I fill with water and use it?
You'll need a very small funnel. only fill with distilled water or you will clog it up after a few uses and it cannot be fixed once this happens. The fill cap may seem loose, the is because it doubles as a pressure safety device. It's fine to seem loose just close it as best you can.
Sep 06, 2015 | Quest Mop Steam Cleaner, 900 Watt
Lance will not produce steam
carl, Ithink your unit is clogged. Clean it thoroughly with vinegar or CLR And it should unclog. Rinse and fill up fresh water and power up! goodluck
Jan 31, 2014 | K?rcher Karcher Sc1020 Steam Cleaner
5 in steam cleaner
try filling it with white vinegar and let it soak for a couple of hours and then rinse it out real good if you have a product called CLR this will work better
Jun 29, 2013 | Heating & Cooling
I believe the thermostat is out on my crofton steam cleaner PSC-350...the light doesn't come on and everything is connected to the thermostat/regulator. Need to know where I can get a new thermostat o
You should be able to find one thru the mfr. or you can check thru Ebay or thru an online search of the part. Just type it in under google and it should bring up places that have it.
Feb 09, 2013 | Home
Just purchased crofton sm 102 steam mop. instructions say will steam when light turns green. ok, it steams for about 10 seconds and thats it!!!!!! tried several times with same results
Apr 11, 2011 | Vacuums
How to take out the water holder to fill it with water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101 ..,/,
May 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Filling the cleaner
cleaner goes in little tank on side. Hot water only no soap goes in the big tank in middle
Jun 25, 2009 | Bissell 1699 ProHeat Clear View Upright...
Kitchen Appliances - Others Logo
55 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
