Question about GE Washing Machines
Drain water from ge washer wssh300g1ww - GE Washing Machines
SOURCE: Our GE Profile Deluxe washer is not draining
Your post says "drain hose is kinked". I assume you meant NOT kinked. You didn't leave a model # so it's difficult to advise. If it's a top loader set it to spin and listen for the drain pump sound. If you hear just a dull hum it's probably stuck with something in it.
Use a shop vac to get the water out. Pull the front off and remove the hoses from the pump. Look into the inlet and you'll see the object.
Posted on Jan 06, 2008
SOURCE: GE washer eill not drain or spin.
water pump is bad or going bad replace water pump will fix this problem
Posted on Oct 23, 2008
kevin_getz
  • 1031 Answers
SOURCE: i have a ge washer model#wssh300g1ww. there is
You either have a bound up (frozen) drain pump, or knowing GE's reputation with washers, the transmission (gearcase) just dug it's own grave. How old is it? Depending on the age, it might have a frozen pulley.
Posted on Dec 16, 2009
beltronic205
  • 1461 Answers
SOURCE: GE Washer Wont Fill
Make sure drain hose not too low , creating syphon...
Posted on Jun 01, 2010
Testimonial: "After posting this question I saw something on the internet suggesting the same. I think this must have been the problem. Thanks for your help!"
SOURCE: my ge washer wssh300g1ww does not spin out clothes
Hello, I too bought one of these washers(WSSH300G1WW). After about one year of operation i noticed that the low spin cycle was making noise so look at it and it was just making noise and not spinning. canceled the cycle restarted the machine but this time set the spin speed to high instead of low, it works on high. im guessing its the clutch in the machine that is faulty and really cant affoard to fix at this time. The thing is i liked to use low spin cause the thing would shake violently on high even with a small load. So now when it spins or i start the machine i make sure theres nothing close that its shaking will cause to fall and break. I also bought the matching dryer (dsxh47eg1ww) it too has problems, the bearings that hold the front of the drum up are going out, thing is i dont over load it and it seems that they went out or started to go out very early as my clothes were getting caught inbetween the drum and the dryer 2 months after i bought it. Im 42 years old so i remember when we had REAL washer and dryers. When quality was revered by companies and consumers. Those old machines ran for years (maybe even decades) without problems, replace a belt from time to time. Now days your lucky to get five years out of an appliance. I know these ones arent going to see 5 years. their about 2 years old and im ready to go find some 1970 model year washer and dryer, rebuild, give a custom paint job to call them retro.
Posted on Aug 14, 2010
My GE washer will not fill up with water.it will go through the cycle as if water is in it and start agitating .Please help --Mark
I had the same problem, with a different model. This is what fixed mine, Model WSSH300G1WW, and may work for you.
First check the screens at the water inlets. Take the hoses off and make sure the screens are clear and not clogged. If they are clear, continue. If not, clean them and retest.
Unplug the power cord, remove the top cover. Mine had two screws on the back. I took these out and then slid the cover back and lifted it off.
Facing the washer, on the right side, near the top, is a sensor? with two wires and a hose. Make sure both of the wires are plugged in all the way. One of my wires was unplugged and plugging it back in fixed the problem.
Aug 26, 2011 | GE WSXH208A Front Load Washer
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
May 25, 2011 | General Electric WSSH300G Front Load...
THe door hinge on my GE front load clothes washing machine model # wssh300G1WW has rusted and bent and the screws are rusted. I would like to replace the hinges and screws but I don't think the...
I have the same washer & its 3 years old today. Rusted hinges & door & screws too.
Door is really hard to shut so I called GE to complain & they are overnighting me a new door, hinges, & screws. You should call!!
Oct 11, 2010 | General Electric WSSH300G Front Load...
GE front load model wssh300g1ww, jumps across the floor during spin cycle, takes 2 people to hold it in place.
ha ha ha! they do dance well dont they???,,,
its the brum suport spring/s broken nothing very hard to fix, and the springs are about £10 each change them both it helps to have two people as the springs are hard to pull into place,wip the top off and you will see the two springs,,if there still there? normaly they just fall off down the back and you need to fish them out from underneath the washer,,,,,,,its a cheap fix realy
Mar 10, 2010 | GE WSXH208A Front Load Washer
I have a ge washer model#wssh300g1ww. there is
Dec 16, 2009 | GE Spacemaker Washer and Dryer Electric...
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
Where to get shipping bolts for wssh300g1ww
Hi Judy
Your best bet would be calling GE and see if there is a part number for those bolts and where you can get those.. Installer usually throw those away after installation..
Here is their tel #1 800 626 2000
Jun 29, 2017 | GE Washing Machines
Washing Machines Logo
19 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
