Question about Dishwashers
Digital display stuck- machine wont work even after reset
I have a bosch exxcel slimline dishwasher. the digital display has stuck on 48 minutes and even switching off at mains will not solve issue. husband has located the reset button- then we tried a quick programme, but display now stuck on 29 minutes and machine not working- any suggestions
    Guru:
  • 462 Answers
Disconnect power from unit. Disconnect ground. Reconnect ground and make sure it is a good ground check hot and nutural to ground and should be line (110 to 120 V) on line (Black to bare) and 0-4 (with a electronic Volt Ohm Meter) White to bare. And again 110 to 120V from Black to White. Reconnect and if ground is stripped make new ground point with new screw. Modern electronics is required to have a good ground and without one readings like yours can freeze. If this dosnt work the board going to the display is most likely broken.
When replacing the board always ground your self before removing the board from the box and plastic bag. This will drain off and static buildup and prevent discharge across the board. (not as much a problem in humid or warm weather).
Posted on Apr 23, 2009
My bosch exxcel dishwasher is saying to check the water how do i do that
There is a water inlet valve (lower front service panel) and solenoid located. Check to make sure that there is no blockage, if the main or other tubing entering or exiting this valve is kinked, the machine will display the check water light. There is also a float switch on the inside of the dishmachine, if it is stuck, the light will go off also. Ensure that water is flowing into the machine, and there are no kinks in any of the hoses. If there arent, look into the float. If it is under warranty, do not attempt to do any of this yourself, call for bosch support first.
Aug 18, 2012 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Need to do a reset on a bosch sgs45e02
when machine is on, press and hold 3rd and 5th buttons (counting from left to right) and front display will reset to zero. Pump will empty water, you will hear it do this about three times.
Feb 17, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
My Bosch Exxcel dishwasher wont clean properly?
the cleaning section is mostly from the circulation pump. is the pump is not working it has to be replaced .go to sears partsdirect.com and check out part first,. this will let you know the prices to fix or replace. then call ten repair person and find the cost to change the circulation pump.
Mar 13, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
I have a Bosch Exxcel Dishwasher, stuck at 1 minute to go
Make sure the drain pump is clear of any blockages and obstructions and that the drain hose wasn't kinked when you re-installed it.
Sep 04, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
390 people viewed this question
Top Dishwashers Experts
