Question about Refrigerators
Ge gss25wgpd bb
Changed water filter. now cant get water to come out of spigot or make more ice
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: In operative water dispenser.
I have GE side by side refrigerator - 2004 model GSH25SGRB SS. From the blog I found out the problem is with frozen water line. If I keep the door water would dispense ( thawing). Or if you disconnect at the bottom ( take the grill out and disconnect) the water would dispense.
I placed a call to GE. The service person came. He said GE could fix with a 3 watt heater. He opened the panel. Pasted a heater. It came in a Y shape form. He connected that to the internal wiring. After some time the water started working.
Part $40. Labor for 15 min work = $210. Total = $250.
This is really should be a recall case. No part broken. They had to design a heater to solve this problem. What a rediculus thing is this. I am trying to call GE and ask to refund.
What a cheat GE!!. F them.
Posted on Jan 07, 2009
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
  • 19 Answers
SOURCE: water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Posted on Jun 18, 2009
Why is it not dispensing water?
Do you have a dual water inlet solenoid valve ? If so one side might be faulity.
Apr 27, 2014 | GE Refrigerators
Gss23qgta bb
Check water cut off then check your water line it may have a kink in it the next thing would be the pump for the water on the back of the frig if you have water dispenser and ice you have two sided pump just because you are getting water does not mean the water is going to the ice compartment. Also unplug and plug your ice maker this may reset it wait 24 hours it can take that long to start working again. .
GE seide by side GSS25WGPD
You will need to see if you run the self diagnostics found in the=> Service Manual The problem with the damper could be caused by a defective thermistor, ice build up or just a defective damper. Your model uses the=> WR09X10050 Damper with Thermistor Assembly Running diagnostics wil help you to locate the problem better if you can read and do the from the Service Manual. I am here if you have questions, Sea Breeze
Sep 11, 2013 | Refrigerators
I have a refrigerator that uses the GE SMART filter. When the filter needs to be changed, the water stops working. I changed the filter -- still no water, yet it makes ICE....any thoughts?
The water valve has two sides. One side is for the ice maker and one side is for the dispenser. If the dispenser side fails you have to change the complete dual water control valve. What is the model number of your GE Refrigerator? Sea Breeze
Jan 10, 2013 | GE Refrigerators
I have a ge side by side model gss25qgmd bb. the water dispenser is not working. I have narrowed the trouble to the tube which enters the bottom of the freezer door and ends at the spigot in the door. I...
I had the same problem. My fix was to disconnect the tube as it enters at the bottom of the freezer door and allow room tempurature( to warm the inside of the tube) and melt the ice in the tube. It took about an hour or so and it worked.
Mitch from PA
Nov 24, 2010 | GE Refrigerators
GSH25KGRE BB water dispenser not dispensing water but it is dispensing ice. Water Filter has been replaced.
I'm not sure what the problem is either but I have the same problem that KDNPGN has (same Model too)
Oct 24, 2010 | GE Refrigerators
ICEMAKER /WATER
The line in the back of the freezer section is froze up. Remove the ice-maker and use a heat gun or hair dryer to thaw. be careful not to put the heat gun or dryer to close. It wont take long to thaw. BB
Dec 15, 2009 | GE Refrigerators
Ice maker not making ice Adora GE
yes I have the light blinking, no ice jam, changed the water filter, so how do I get ice?
Mar 22, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Water dispenser not working but ice maker does
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
