Question about Chanel Clothing Accessories
Chanel glasses - CC diamante logo broken - screws come away from CC logo no longer stay attached to glasses side arm where can I order the CC diamante logo for glasses 2051b ? Thank you
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I need to replace the lenses and a missing chanel
You can contact the link below for replacement parts for your glasses.
http://www.sunglassreplacementlenses.com/
Posted on Apr 09, 2011
How do I change the glass in the outside mirror on a 2003 Lincoln towncare
behind the piece of glass there is a black plastic that the glass sticks to if you push it to one side stick your fingers behind it and pull you will disconnect the glass retainer from the mirror motors bracket do this on both sides of the mirror and make sure you don't lose the little barrel shaped arms that snap the glass retainer into the window motor housing where glove for broken glass splinters sometimes it's best to put those barrel arms in then press the glass in but I would say it's better to try to fit the arms in while attached to the glass it depends how big your hands/fingers are for the space allowed to get it in GOOD LUCK STEPHEN
Feb 04, 2015 | 2003 Lincoln Town Car
Only one side of my rear window on my 1995 4Runner will start to roll down when the switch is actuated. Upon taking the panel off, the arms are working but one side isn't coming down with the arm. How
COULD BE THE MOST COMMON TYPE THE GLASS IS CLAMPED IN A RUBBER SHROUD WITH A METAL SLOT AND THIS HAS CORRODED AWAY ESPECIALLY ON A VEHICLE IN NORTHERN CLIMES
Nov 29, 2011 | 1995 Toyota 4Runner
I need to replace a busted out driver side back seat window. already have the glass but want to replace it myself
You need to remove the door panel to replace the window.
To remove the door panel, remove any screws that are in the vicinity of pull handles and door pockets. These screws will be under little trim covers that you need to prise off to get to their heads. Look for the screws around the edge of the panel and also the screw in the latch release handle recess.
The lock knob, if there is one there, will have to be screwed off and then carefully work your way around the door, freeing the panel's clips from their holes in the door frame. (Doot panels are brittle and clip break out easily).
Finally the panel will probably have to be lifted out if the window slot. (If the panel does not come off, work out what is retaining it and remove that screw or slide it off the clip that is still holding the panel. Disconnect any electrical plugs behind the panel. Under the panel you will find a plastic dust sheet that is stuck to the door frame, remove this carefully, you will have to replace it before replacing the panel.
Once the panel is off, you will see the attachments for the window retaining chanel and how it is attached to the winding mechanism. You may have to loosen off the bottom window runner attachments as well. Once everything is disconnected, remove the old parts and then you have to work the window in through the slot at the top od the door, slanting it so that it will fit into the door. Then align it in the runner slots and attach all the fasteners again. After you have put everything together, check the operation of the window before replacing the panel. It is a fiddley job and you will be working through limited access ports but it can be done - good luck and please rate this response.
May 19, 2011 | 1997 Chevrolet Cavalier
My KRUPS FBC2 glass door hinge is broken. We use a pan to keep door in place when using it so it doesn't fall down. Any ideas on how to fix it will be appreciated. I'm pretty handy with things but I just...
I just fixed the problem with my Krups FBC-212. The door would not stay closed because the spring that keeps it in the closed position was broken. I ordered another from one of the small appliances parts sites (about $7 plus shipping) and that fixed it. I will describe how to do it and how to avoid the mistake that made it much harder and longer than it should have.
Remove the black screws at the back side, the ones holding the external black metal case to the silver chassis. There are 9 of these on my oven.
Also remove the 3 screws holding the left-side foot on.
Now you can probably slide the metal case (previously held on by the 9 screws) out from under the black metal front frame on the left side, thereby exposing the broken spring.
If you cannot get it out from under the lip of the front frame, you can take off the right-hand foot, and if that is not enough, you can remove THREE of the 4 black screws just inside the door holding the front frame to the chassis. Do NOT remove the lower left one next to where the flat door hinge piece goes into oven (which was my mistake) because that screw holds a critical black plastic piece in place.
By now you will be able to slide the black case that covers the sides and top backward and outward enough to expose the broken spring. It will be obvious how to attach the new one.
Aug 28, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
How to install passenger side glass on a 1997 gmc sierra 1500. power windows.
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Remove the clips and screws securing the old window to the arm and slide it out through the top of the door (may need to be maneuvered out)
Sep 10, 2009 | GMC K1500 Cars & Trucks
Power Windows go up or down Crooked
yes there is a broken clip on one end or the window .. you will have to take it appart and see which one is broken and order it from a dealer .. some auto parts carry these little deals they are plastic and they screw into both sides of the glass with a arm on one side for the chanel operation.. thanks Jerry and holler if you need more.
Apr 13, 2009 | 1988 Ford Bronco II
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Jenn Air Expressions radiant module for CVEX4370
Found the solution. It was a simple one duh! Six screws. After looking at the picture of the glass and realizing that the glass comes on a frame, I noticed the screws just below the glass on the cartridge. The glass frame sits inside the base of the cartridge. It took about 5 minutes. mmaque
Jun 27, 2008 | Jenn-Air Expressions CVEX4370 Electric...
Clothing Accessories Logo
49 people viewed this question
Top Chanel Clothing Accessories Experts
Da Doc
ray gallant
Tom Chichester
Are you a Chanel Clothing Accessory Expert? Answer questions, earn points and help others
