Question about Sony VAIO VGN-N110G/W Notebook
Moition eye problem
MOITION EYE IS NOT WORKING,AFTER AN UP GRADE WAS MADE
I have po code 106.engine won't rev above 2500 And my 04 Ford explorer, and my sensor doesn't seem to be dirty
you will need ford grade investigation equipment , judging by eye if its clean or not will not help as it is an electronic problem with the PCM and MAP / and or BAROMATIC PRESSURE sensor, take to a ford experienced mechanic
Jun 01, 2015 | Ford Cars & Trucks
Hi everybody i have a Lexus Gs300 2006 after an oil change i an it for 5000mile and i found that engine oil is lost about 1.5liter what is the problem? thank
hi, do you see oil on ground when you park? - could be oil drain plug is not put on properly- also, do you see blue smoke coming from tail pipes?- could be bad piston rings---- look for ooil in engine bay -look down and see if leaking- that's a lot of oil to lose- keep an eye on oil level every time you start the car to avoid severe engine damage!!!- put oil as you need until fixed- happy trails!!
Jan 03, 2015 | Lexus Cars & Trucks
Will not start
dry your spark plug, spill out the old oil/fuel mix and put it all back together but use a good grade of oil made for 2 cycle motors and mix the fuel/oil mix precisely to what the manufacturer recommends. don't eye it, or mix at a general spec.
Apr 20, 2012 | Garden
My eyes burn when unit is in low and med but not in high setting.is it the presure setting?
Yes it could be the pressure and maybe even the grade of fuel you are using. K1 Kerosene is the fuel of choice and it even has a stench factor to it. You can back your pressure down slightly but this can cause a flame out situation then you are talking serious stench.
Dec 12, 2010 | Dayton (3VE56) Gas Utility Heater
Sony vaio motion eye
Yeah.... i can understand... Simply download the drivers of your MOTION eye from the Website of Sony Vaio laptops... by doing this it will rollback the upgrade and will automatically install proper drivers needed to make it work... RATE my solution it helped you really...
Apr 23, 2009 | Sony VAIO VGN-N110G/W Notebook
91 toyota celica 2.2
chances are your transmission is slipping
Apr 11, 2009 | 1991 Toyota Celica
Cleaning the mirror?
usually near the controls there are some screws, remove, then lift aggressively without breaking. Use a eye glass cleaner from Wall mart or such. Need near lab grade alcohol. Can use DEP (home depot) glass cleaner. Be gentle use baby diaper and swab in one direction.
Mar 10, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Stainless Steel Range Tops.
try using stainless steel magic we use it here it works good
Aug 29, 2007 | Kitchen Ranges
Sony VAIO VGN-N110G/W Notebook Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
