Question about Chanel Clothing Accessories
Chanel cc diamante logo broke
Timing belt broke on my 1994 Diamante would there be damage to engine
Well the 3.0 engine is not supposed to be an interference engine.
But it is possible some valve damage occured when the belt broke at that speed.
You won't know for sure until the new belt is installed.
Mar 12, 2015 | 1994 Mitsubishi Diamante
What are the outstanding features of designer sunglasses?
Designer sunglasses receive most of their popularity from trademark logos and designer-specific prints. For example, a large part of the success associated with the Chanel label can be attributed to their back-to-back C logo. It's a known fact that merchandise featuring notorious logos sells better than those without. Likewise, the Burberry label has become synonymous with their camel, red and white plaid print and Lacoste with their crocodile logo.
Nov 07, 2010 | Clothing Accessories
Antenna broke
Open up your trunk. Remove the felt cover. Check near the antena motor, there should be a socket that can be unplugged so that your antena does not continue to run.
Mar 08, 2010 | 2001 Mitsubishi Diamante
I just got a 1993 MITSUBISHI DIAMANTE timing belt broke and was fixed the right way but still won't start
do a compreshion test on the engine you may have bent the velves or even put the belt on a fuw teeth out check the timeing as well that could also be out,
its very easy to let the gears slip out a bit when fitting on a new belt
Nov 08, 2009 | 1993 Mitsubishi Diamante
I have a 98 mitsubishi diamante that overheated now the car wont start and when i crank it it sounds like the timing is of it whines
Sounds like it may have blown a head gasket, and or craked/warped a cylinder hear or engine block. If possible, pull all six spark plugs and look for evidence of engine coolant on the electrode.
Oct 23, 2009 | 1998 Mitsubishi Diamante
Cosmetic
a fiber glass kit for car repairs should work to repair the shell
Jun 06, 2009 | Infinity CC-3 Speaker
Can not hear no body but can hear weater chanell.
Make sure your wire going from the radio to the antenna is not pinched or broke or split any where.If all your wires are good then you antenna is just not high enough to pick up signal.
Apr 01, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
1992 Diamante troubles - electrical
start by putting the old one back to see if everything works.
May 28, 2008 | 1992 Mitsubishi Diamante
Clothing Accessories Logo
29 people viewed this question
Top Chanel Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Chanel Clothing Accessory Expert? Answer questions, earn points and help others
