Sanyo sfx25 changed carriers and only get a busy signal when trying to fax
rmeyer
  • 80 Answers
SOURCE: Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Posted on Jan 09, 2009
goalie39
  • 469 Answers
SOURCE: Fax line is busy
check the hand set is correctly seated on its cradle.
Check the Hook button on the front of the machine.
Disconnect the fax machine from both the phone and power lines for several minutes, reconnect and try again.
UserGuide
.pdf">http://static.compusa.com/pdf/canon-FAXPHONE_L80-UserGuide.pdf
I have included a copy of the users manual in case you are missing yours.
Hope this helps
Ed
Posted on May 20, 2009
SOURCE: I can receive faxes but get a reorder signal (fast
HELP ME TO INZTALL MY FAX BROTHER INTELI FAX 2820 I DO NOT HAVE THE DISC
Posted on May 22, 2009
FixinFax
  • 3085 Answers
SOURCE: trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
Posted on Jun 04, 2009
  • 10 Answers
SOURCE: Busy Signal
I called Canon about this. They had me tweak the transmission start speed (Menu>FAX setting>TX settings>TX start speed). It was too fast. Set it to 4800. Then it was too slow. Clicked it up to 7200 and now it works!! TX Start Speed should not be too fast or too slow.
Posted on Mar 13, 2013
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
Why do we get busy signal for every fax we send?
Check the lines and check the connection, usually it's a problem from your side, There is a nice troubleshooter in the manual so check it out: Brother Intellifax 1270e manual
Jul 23, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
Every time I try to fax I get a busy signal. I tried to fax several places and I get the same thing cannot be completed as dial.
dial those numbers from a regular phone and listen for fax tones. If you hear a busy signal, then they are busy.
Jan 14, 2010 | Brother FAX-575 Plain Paper Thermal
When trying to fax, iam getting a fast busy signal, this problem just strated
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Aug 29, 2009 | Office Equipment & Supplies
Trouble faxing
May 31, 2009 | Samsung SCX-5115 Fax Machines
Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
Mar 03, 2009 | Ricoh Office Equipment & Supplies
Sanyo pm 8200 sprint service no signal
Not sure about the bars, but you can go to the settings in the main menue and try to go to roam only. It could be that you r carrier is having a problem with their tower. Your phone, normally, will try to stay on your carriers towers. If you force it to a roaming status, you might get a better signal, but on a roaming network.
j
Jun 24, 2008 | Sanyo PM-8200
Incoming fax
Do you have the manual? Check your smart ring feature.
Sep 05, 2007 | Brother IntelliFAX 2800 Laser Fax
16 people viewed this question
jasbo
jasbo
