Question about Office Depot Ativa DQ60M Shredder
Overhead Overload light keeps coming on Staples SPL-1506X Shreder
Bin is empty, And not overhead but light keeps coming on and it auto turns off.
Have cleaned with compressed air, and cleaned electric eyes.
Any ideas?
  • dvermillion Apr 29, 2009
    overheat overload light comes on. I have cleaned, oiled, compressed air, everything, but nothing fixes it.
3 Suggested Answers
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
  • 300 Answers
SOURCE: Automatic switch does not shut off after shredding
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Posted on Feb 14, 2011
Sentinel Pro On Guard shredder just stopped working
Mechanism could be clogged with debris, causing motor overload and thermal shutdown.
Dec 13, 2016 | Shredder Office Equipment & Supplies
Staples SPL-QW120D shredder is stuck on "Bin Full" even when empty?
Check operation of the bin interlock inside the area where the bin fits. It may be damaged/defective.
Sep 16, 2016 | Staples Office Equipment & Supplies
Where can I obtain a repair manual for a Staples SPL 1506X Shredder
You can't. You take it apart yourself, you find the cogs inside are plastic and shattered and you can't get replacements, so you have to buy a new one.
Apr 09, 2016 | Staples Office Equipment & Supplies
How to oil shredder staples spl-1506x?
You can buy commercial products, or run some wax paper through your machine periodically. The wax will not gum up like oil and attract dirt.
Jul 13, 2014 | Staples Office Equipment & Supplies
Automatic switch does not shut off after shredding on Staples model SPL-1506X shredder.
Feb 13, 2011 | Staples SPL1506X (CrossCut) Shredder
Domelight overhead storage rail replacement
  1. Depress the side tabs and remove the overhead storage bin.
  2. Remove the overhead console.
  3. Disconnect the 2 overhead console electrical connectors
  4. Remove the dome lamp assembly.
Jan 31, 2009 | 2006 Ford F-150
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
Shredder problem
Call us at Fellowes Customer Service 1-800-945-4545 On Monday between 7am and 7pm Central Standard Time
Feb 23, 2008 | Fellowes DM15C Shredder
No power to SPL-1506X
I had the same problem-one day the shredder worked, the next day no power. We checked the fuse and it was ok. There is a safety switch that has to engage with a plastic tab on the bin. For some reason it was no longer engaging. We put a piece of cardboard into the slot and now it works fine.
Jan 06, 2008 | Office Depot Ativa DQ60M Shredder
Office Depot Ativa  DQ60M Shredder Logo
127 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
