Question about Indesit Kitchen Ranges
Wiring a indesit hob and oven
Can i hard wire a hob directly into existing cooker control unit...the existing unit is a 45amp with a socket....if yes what size wire
also as the oven comes with a flex and plug can i plug this into the socket on same unit
  • Farley Redfield
    Farley Redfield May 11, 2010
    Whish I knuew what a hob is. (Hob = HOBBY to me)
  • MajorClanger May 11, 2010
    If the Oven is a single Oven type and seeing as it has a flex and plug (should be 13amp)you can plug it in on the cooker circuit.
    As for wiring the hob in you should use 30 amp cable.
    Guru:
  • 462 Answers
Minimum wire size is at least #8 and maybe #6 depending how far you are from breaker box. If close to 100' (75 or more) Go the #6. But Im not sure what a hob is.
Posted on Apr 23, 2009
How do you know if your oven is hard wired in or plugged in if can't see it?
The wiring should go to a cooker switch box...usually found at the back of an adjacent cupboard or on the wall. This will usually have a large red switch with a power indicator light and a standard switched socket.
On most installations of seperate oven and hob...the hob will be hard wired to the big red switch and the oven will be plugged in to the standard socket. So switch the socket off and see wether your oven is off...if the oven is connected to the big red switch instead then it must be hardwired...
Feb 13, 2012 | Ovens
HOW TO WIRE A SINGLE INTEGRATED OVEN? Can it be wired into the mains cooker point?
An integrated oven that has a 13 amp plug can be wired into a cooker point without any concerns since you are wiring it into a feed that is capable of handling a greater power requirement than is needed.
For the avoidance of doubt, the other way around, if you are considering putting a 13 amp plug on a unit that is designed for direct hardwiring into a cooker point, you should think again because it is probably capable of drawing more current than the 13 amp socket could safely handle
Jul 19, 2011 | Ovens
Do all neff oven & hobs have to wired in using 6mm cable or can they be wired into a13 amp system
If it is a single oven on it's own then it can be used from a 13 amp plug and socket, the same with the hob, if it is seperate from the oven it can be used from a 13 amp socket.
If it is a combined unit, then it will have to be hard wired to a seperate circuit using 6mm twin and earth cable, and fused on it's own circuit.
Nov 07, 2010 | Neff B1421 Electric Single Oven
What if the full electrical load for the dtc95df
As the dtc95df needs to be wired directly into a cooker outlet it suggest that the appliance needs a minimum of a 30amp circuit.This is to cover all electrical side of the oven being on at the same time.The cooker circuit must be wired in a minimum csa twin and earth cable of 6.0mm and switched through a double poll switch.This would be fused back at the main db board with a min 30amp breaker or 45amp breaker.Cooker switches are rated at 45amp. hope this helps
Jul 19, 2009 | DeLonghi CTH2003 2-Slice Toaster
Beko D533 cooker only half working
where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
Dec 07, 2008 | Ovens
Rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Apr 05, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Wattage for double oven
im getting a indesit fid201 double oven does it have to be hard wired or can it go on a 13amp plug
Feb 14, 2008 | Ovens
Kitchen Ranges Logo
533 people viewed this question
Top Indesit Kitchen Ranges Experts
Greg Cann
Greg Cann
paulcarew
Owen Barnes
Are you an Indesit Kitchen Range Expert? Answer questions, earn points and help others
