Zanussi 6hg e10 - Washing Machines
2 Suggested Answers
  • 25 Answers
SOURCE: e10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Posted on Feb 28, 2009
I have a zanussi 6hg 1200 rpm it's flashing error code E 60 what does it mean
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Mar 24, 2015 | Zanussi Washing Machines
Zanussi 6hg 1400 rpm won't drain
My machine won't fill up with water and I noticed it started flashing e21 and its not spinning very well either what could the fault be
Aug 17, 2012 | Zanussi ZWF1430W Front Load Washer
Washing machine showing error e10 ??
E10 is an inlet error, or not filling water properly.
Firstly, check the inlet filter (situated on the machine, where the inlet hose turn into)
Then open the machine and check the Inlet Valve (You can attach power to the 2 points to see if the solenoid opens or not)
Good luck :-) - J.Q
Feb 16, 2011 | Zanussi Washing Machines
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
ZANUSSI FJR1454 W WASHING MACHINE E10 ERROR . IT TAKES NEARLY THREE HOURS TO DO A QUICK WASH. IT BLEEPS AT LEAST 4 OR 5 TIMES THROUGHOUT A WASH CYCLE AND THE CYCLE COUNTER DOESNT SEEM TO COUNT DOWN...
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 10, 2009 | Washing Machines
I am constantly getting a E10 error on my Zanussi w1042w. what could be causing this?
Jul 14, 2009 | Washing Machines
My Fridgidaire front load clothes washer model ltf2940es3 is showing error message e10
May 03, 2009 | Washing Machines
E10 code on a zanussi jet system washer
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
