Question about Home Security
Break sentry ksw 3632 - Home Security
I lost a key of my safe
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Homelb_icon1.png/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. They key ordering screen is: www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
For Small Chests or Files: (Model numbers will begin with 0500, 1100, 1110, 1150, 1160, 1170, 1710, 1900, 1950, 1970, 1200, 1210, 1250, 2100, 2180, 2275, 2460, 6000, 6720, 7150, A3750, A5781, A5865, F2300, F3300, H2100, H2300, H3100, H2300, H3300, H4100, H4300, HD2100, HD4100, KDS-1, KS2100, KS4100, U2101, WD2, WD4, ESB-3, etc... ): A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock (right around the hole where the key goes in at).
For Personal, Home and Home/Office Safes:(Model numbers will begin with: S0 (S0310, S0400, S0407, S0408, S0409, S0410), S3 (S3300, S3310, S3401, S3410, S3417, S3421, S3460, S3467, S3470, S3710, S3807, S3870, S3877, S3910), S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, CS, CSW (CSW3460), DA (DA3831, DA3930), DS (DS3410, DS3431, DSW5781), KSW, MS, MSW, OA (OA3810, OA3821, OA5848), OS (OS0407, OS0410, OS0810, OS3407, OS3421, OS3470), SC, and X (X031, X075, X105, X125)): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges. Keys Sentry Safe Replacement Keys Keys Sentry Safe Replacement Keys
Apr 07, 2014 | Sentry Fireproof Safe
Im lost key for my sentry safe box serial BD608488
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A52_bing.gif; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Jun 16, 2010 | Sentry Fireproof Safe
I bought a S 3417 SENTRY SAFE S/N Z 583159* AT A
In Summary:
Combinations can also be ordered from the same website.
Mar 04, 2010 | Sentry Fireproof Safe
I have a sentry 1100 safe and have missplaced the key. Can I get a new one and how?
You can go to www.SentrySafeShop.com and do a search for keys. You will then be able to enter your information as listed below and they will send out a new set to you. For Small Chests or Files: (Model numbers will begin with 1100, 1160, 2100, etc... ): A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock (right around the hole where the key goes in at).
For Personal, Home and Home/Office Safes: (Model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Nov 16, 2009 | Sentry Fireproof Safe
I lost the keys to my Sentry Safe 2180
In Summary:
Oct 27, 2009 | Sentry Fireproof Safe
Lost key
We cannot legally provide any information about safe opening. We have no way of checking to see if you are a burglar. Contact a safe company in your area or ring SENTRY and they will check the REGISTERED Owners details and then send someone to either open it or arrest you.
Thanks for using FIXYA
Sep 24, 2009 | Sentry Fireproof Safe
No keys to my sentry 1100 fireproof box.
Aug 30, 2009 | Sentry Fireproof Safe
Lost key sentry model 1170, where can I get a duplicate key?.
A locksmith can fit keys the the sentry safe 1170. Sentry safe lost key replacement is availble. You do need to know the key # that is on the face of the lock to cut a 1170 key by code.
Jun 08, 2009 | Sentry Fireproof Safe
MSW3517 Book inside
In Summary:
Apr 22, 2009 | Sentry Fireproof Safe
Home Security Logo
46 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
