Question about GE 30 in.Profile JGP945 Gas Cooktop
GE Profile gas cooktop JGP970 control locks buzzes even though in the unlock position
  • 10865 Answers
SOURCE: I have a GE Profile
the ignitor switch for that particular burner is stuck in the on position. I may have some debris in it which is causing the problem. you could try to clean it using a blast of air from a keyboard air cleaner aerosol can, available at any office supply but most likely you will have to replace it.
Posted on Aug 17, 2009
SOURCE: can't get GE profile cooktop clean
Don't buy one is a good start unless you like to spend a few hours everyday attempting to make it look clean. If you are OC you'll love the cooktop BTW. Crappy engineering and source selection. Include it in the price when you move.
Posted on Oct 19, 2009
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
heatman101
  • 43501 Answers
SOURCE: GE Profile JGP636 gas cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 21, 2010
heatman101
  • 43501 Answers
SOURCE: I just spilled water onto my gas cooktop and now
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 30, 2010
GE Profile Gas cooktop burners blow out
This sounds as though the pressure is too high.
Feb 11, 2015 | General Electric PGP953DETBB GE Profile...
Tip
Ge jgp328 30 in. sealed gas cooktop
Do anyone know now to turn off the control lock. My stove still lights with the lock on. But it still makes the ticking sound.I am told it only does that when the lock is on.
on Mar 13, 2009 | GE Profile JP930 Electric Cooktop
GE gas cooktop modelJGP970BEK2BB. The unit is in the unlocked position, burners will light, but "lock" light remains on and buzzer/alarm sounds the whole time?
The lock switch will need to be replaced. Lock switch, the switch has failed and causes the buzzer to run. Not a difficult repair but the top will need to be remover to fix this. This is not advisable to repair if your not knowledgeable with the installation part of this unit.
Good Luck
Jul 19, 2011 | GE Profile JGP636 Gas Cooktop
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
The on/off gas switch keeps buzzing in the on position!
Each gas valve has its' own ignitor spark switch.
One or more of your switches has shorted out.
Remove the panel to access the switches. Remove the wires from one at a time until the sparking spots. That will be the bad switch.
Mar 25, 2009 | GE Profile JGP636 Gas Cooktop
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Hello posted this question but family getting antsy without a cooktop. I am installing a 36 inch GE Profile gas cooktop, jgp970, along with a Frigidaire downdraft vent, pl36DD. The gas inlet pipe on the...
the reason for the fitting instruction for the regulator to be connected directly is that flex hoses deteriorate and allow a dangerous situation
AS gas is not in the diy domain I recommend that you get in an accredited gas fitter who will make a solid pipe to allow the fitment of the regulator away from the motor
While he is there he can adjust the regulator to get it all working correctly
Mar 13, 2017 | GE 36 in.JGP970 Gas Cooktop
Poor gas flow to GE cooktop
Try a bigger inlet pipe sounds like pipe too small for load .
Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
GE 30 in.Profile JGP945 Gas Cooktop Logo
111 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
