Question about Microwave Ovens
I pluged the microwave in it was working and when I pushed it back and when I looked at it it waqs not working any moren mdl # is 87449 kenmore counter top microwave
    Sniper:
  • 52 Answers
Check the outlet it is plugged into. Remove the microwave plug. If you don't have a voltage meter handly to test the voltage at the outlet or the continuity of the microwave plug, I would suggest you plug in a lamp from your living room into the outlet. If it doesn't work, either the outlet is a tripped (GFIC) Ground Fault Interuption Circuit outlet or the circuit breaker tripped in your electrical panel box or the microwave cord is damaged and caused a short and blew the fuse. To check these I would try plugging the light in and press the red reset button located on the wall outlet or flip tripped circuit breaker in panel. If it's a damaged cord or fuse, you can visit this web site for Sears parts www.searspartsdirect.com If you found any of these suggestions helpful, please rate my solutions. Thanks D. Lange
Posted on Apr 25, 2009
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
I have a Kenmore Microwave 405.72123310. The microwave turns on and the turntable turns, but it does not heat. Is there a fuse I can check for this?
You really don't want to take them apart do to radiation. Take the screws out in back plate. Carefully and remove and look in to see if you see black burnt spots. If you see any then chances are the main board shorted out on microwave.DO NOT STICK ANY TOOL IN MICROWAVE IN BACK. Some do have a round fuse in back.If your does take it out with some heavy plastic. Make sure before you take back off unplug from wall and the push start 3 times with 5 second apart. This will allow all electric in the power reducer to discharge. then you can work on it. On sides of use it will tell you what amps it is. Good Luck
Aug 03, 2016 | Kenmore Microwave Ovens
Microwave won't heat
check magnetron section and high voltage section any thing wrong
Aug 09, 2015 | Kenmore Microwave Ovens
The display screen on my Kenmore Elite Microwave model #721.80802400 has frozen on 13 seconds! does not respond to turning or pushing dial. Only works by pushing manual. No idea about cook times. Is this...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still doesn't work, it may be a controller issue which can be repaired.
Feb 25, 2011 | Kenmore 80809 Microwave Oven
Model 63259 bought about 2 months ago. I went to
you can check and see if there is a fuse on the microwave, if not it may have just burned out, its probably still under warranty so try to take it back for a replacement
Jan 14, 2010 | Kenmore 63252 Microwave Oven
Kenmore Microwave Hood Combination 721.80019 does not heat. I follow all the troubleshooting procedures. Nothing solved the problem. Help!
My kenmore microwave will not work. The light stays on inside, buttons will push, but the start button does nothing. I've tried everything. The last thing I did was express defrost which was fine. Could it be something really simple? I hope so.
Nov 14, 2009 | Kenmore 63792 Microwave Oven
Galanz Microwave problem
its more likely to be a fuse from the transformer to the cap or the diode.
Sep 14, 2009 | Microwave Ovens
Will not start when pushing start button
Check the door switch is properly working. If it is ok the defect may be with the key pad.
May 23, 2009 | Frigidaire Mid-Size Microwave
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
132 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
