Question about Sharp Xe-A507 Cash Register, 7000 Lookups, 99 Dept, 40 Clerk
Xe-a507 how to delete upc out of register? - Sharp Xe-A507 Cash Register, 7000 Lookups, 99 Dept, 40 Clerk
We have to always push the drawer in 2-4 times before it actually closes (sharp XE - A507 Cash Registers)
Adjust the latch at the rear of the drawer. The catch may have bent or the solenoid is sticking and needs cleaning.
Jan 17, 2017 | Retail Supplies
How to program bottle deposit on xe-a507
PartsandTheirFunctions Printer cover Operator display Keyboard Drawer Check slot Drawer lock SD card slot (Refer to the "SD CARD Mode" section.) Printer The printer is a thermal printer, and therefore it does not require any type of ink ribbon or cartridge. The average life of the printer is approximately 6 million lines. When removing the printer cover, lift up its rear. When installing the printer cover, hook it on the pawls on the cabinet and shut it. CAUTION:Thepapercutterismountedontheprintercover.Becarefulnottocutyourself. Keyboard ? Keyboardlayout ? Functionkeylist { Receipt paper feed key PLU/sub-department/UPC key } Journal paper feed key Department code entry key Function menu key Department shift key a Auto key CLK# Clerk code entry key w Tax1 shift key Department 1-40 key 0 Percent 1 key FI Cursor (up/down arrow) key - Discount key m Mode key t Void key Escape/Cancel key H Help key X Charge 1 key f Refund key R Receipt print key @ Multiplication key Y Charge 2 key P Decimal point key u PLU/UPC inquiry key l Clear key x Check key 0 9 : Numeric key ; Non-add code/Time display/Subtotal key A Cash/Amount tender/No sale key Displays ? Operatordisplay •Screenexample1(REGmode) Salesinformationarea: When a transaction information occupies more than 2 lines, you can scroll to the direction by using the F I keys. Sales information you have just entered such as items and prices will appear between 1st line and 2nd line. Total is always appear at 3rd line. NumericEntryArea: Statusarea: Mode name Status information Clerk code Receipt ON/OFF status indicator (R) : Appears when the receipt ON-OFF function signs OFF. Sentinel mark (X) : Appears when the cash in drawer exceeds a programmed sentinel amount. The sentinel check is performed for the total cash in drawer.
Sep 28, 2016 | Sharp ELECTRONICS CORP. Xe a203 cash...
Why has cash register stopped working all of a sudden?
Amazon.com: Customer Reviews: Learning Resources ...
www.amazon.com/...Register/product.../B0006N8X3...
Amazon.com, Inc.Learning Resources Pretend & Play Teaching Cash Register ... However, it recentlystopped working and simply said 'DRAWER OPEN' no matter what we tried ...
Casio - Support
www.casio.com > Home > Support > FAQs
CasioFrequently Asked Questions - Cash Registers. ... How I fix my cash register if the Journal/Receipt is not printing? How do I load paper in my cash register?
Not Assigned Error Message On Sharp Cash Register ...
? 1:06
https://www.youtube.com/watch?v=cq1_zcY_DuQ
Jul 12, 2010 - Uploaded by shopstuffltd
Instructions on how to clear the 'Not Assigned' error message on the Sharp XE-A203, XE-A213 or XE-A303 ...
"Head Up Error" on a Sharp cash register - YouTube
? 2:53
https://www.youtube.com/watch?v=NXMbLjfjdro
Jan 15, 2013 - Uploaded by sharpelectronicsusa
Clearing the "Not Assigned" and "Head Up" Error on the XE-A40S, XE-A41S, XE-A42S, XE-A401, XE-A402 ...
Re: Cash register notification stopped working - The eBay ...
Dec 12, 2015 | Royal Alpha 1000ML Cash Register
XE-A507 register beeps after every transaction and has x01 on screen How do we get this to go away?
Did you sort this problem? It might be a journal problem. Let me know if it is still causing problems
May 17, 2015 | Retail Supplies
When I plug in the barcode scanner it stays on flashing and will not scan a barcode
Hi Carolyn
I am going to presume that you have not set up the Barcode scanner yet with the barcode EAN defaults etc? Please take a look at the PDF document via the link below and go through the setup process for the barcode scanner.
Andrew
Sharp XE A507 Cash Register
Jan 08, 2014 | Sharp XE-A507 Cash Register with Hand...
How can you print the barcodes
The bar codes are on the products. I'm not sure what you are trying to achieve.
Aug 04, 2012 | Sharp XE-A507 Cash Register with Hand...
Deleting upc codes from a Sharp XE-A505 cash register
Hello there,
To delete UPC codes, please refer to this portion of your manual.
Hope this answers your problem. Goodluck!
Sep 25, 2009 | Casio Parts Cash Register PC Desktop
Sharp Xe-A507 Cash Register, 7000 Lookups, 99 Dept, 40 Clerk Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
