Question about Canon Office Equipment & Supplies
Canon ir8070 printing from adobe reader5.0 is too slow
Ir 8070 copier. How do I correct a print suspended error?
please perform a main controller clear from service mode
May 23, 2015 | Canon IR 8070
White copies from canon ir8070 how can I solve it
Tough to diagnose without seeing the machine in person, but white copies on that model are usually caused by one of the following issues:
1. Developer assembly issue or magnetic roller bad
2. Problem with the Charge or transfer corona assemblies
3. Or an issue with Drum Potential control
Nov 23, 2014 | Canon Office Equipment & Supplies
Canon IR8070 paper jam infront of Registration roller
If you can reach the paper in the jam you will have to pull it out to dislodge the jam. Be careful not to rip the paper in doing so!
Aug 28, 2014 | Canon Office Equipment & Supplies
Error code E-00830 in IR8070 canon
check the corona a high voltage is detect from the machine. try to clean in and see if it works.
Feb 15, 2012 | Canon IMAGERUNNER 8070 Copier
IRC 3220 Color Copier when printing pdf files is very slow. A 2 page document takes 2 hours to print. please help.
Hello pd.
I suggest you remove and re-install your print driver and make sure you install the CANON UFRII print driver available at the Canon web site. Also, Adobe 8.0 has a known problem with this and you can go to their website and they have a patch for this problem, I hope this helps.
Feb 16, 2011 | Canon imageRUNNER C3220 Color Copier
Canonir3530err code e000602-0102
you need hard disk check, from service mode,
if not solved format hard and install system
if not solved replace hard
Oct 11, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Pls i need the canon ir8070 frimware
I can get it for you, do you already have SST installed on your xp laptop computer?
Contact me for more info. ultimate_sacrifice@msn.com
Mar 05, 2010 | Canon Image Runner 3320I Copier
Ir 3245 slow printing on pdf files
This may require a firmware update or even try printing the PDF file from a different version of Adobe.
Jun 25, 2009 | Canon Office Equipment & Supplies
How do i print from the memory, lost my manual?
You will need Adobe Reader to open the manuals
if needed download using the "Get Adobe Reader" button at the following link
http://www.adobe.com
You may wish to bookmark this link in case of future issues
Review Chapter 8 page 12 refers to Chapter 14 page 7
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=241&modelid=9986#SupportDetailAct
Dec 07, 2007 | Canon FAXPHONE L80 Laser
18 people viewed this question
old marine
old marine
