Question about Vacuums
Got window vac, Powermax VRS1WV can't get spray to work
Where can I get a repair manual for a bosch powermax 1700w vacuum cleaner?
You won't likely find one anywhere. Bosch pulled the plug on vacuums several years ago. Take it to your local vac repair shop if you need repair. I'm not allowed on here to give you my store info as it's seen as self promotion, but do a search in your area for former Bosch vac dealers and you should be able to find a qualified expert near you.
Jan 08, 2015 | Bosch Vacuums
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
How to replace Hoover PowerMAX power nozzle cord?
You can get the new cord at your local vac shop or you can take the power nozzle to the shop and have it repaired
Apr 27, 2017 | Hoover Powermax S3601 Bagged Canister...
HOW TO REPLACE BRUSH BELT ON A HOOVER POWERMAXll VAC. DWSMITH1624@AOL.COM
bottom of vacum theirs clips un latch them it comes off then remove the brush upward then switch belts
Mar 25, 2010 | Hoover Powermax S3601 Bagged Canister...
How can we avoid the odor that we usually have with other vac exhausts? will cleaning the filters as suggested really keep that from happening?
Bagless vacuums have a real problem with bacterial growth. That is what produces the odor you are smelling. Wash the cup in an enzyme and the filters too if they are the washable type. Make sure everything is dry before you reassemble the vac. Then turn on the vac and pull the hose out like you would be using the tools. Holding the hose end that has the suction, spray a small burst of Lysol Spray into the hose opening so the vacuum "sucks" the Lysol through it's interior. This will kill the bacteria in the hose and the plastic housing of your vacuum. Usually 3 bursts works fine. If you spray too much and get your machine "wet" with the lysol you could damage your motor so small bursts are better than a long spraying action
Oct 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a new steam vac power max without instructions I need to know how to operate it
Hiyas ive found you an online downloadable manual go to this site and after its loaded look where it says product manual and click on that then click on the product manual again and it should open a new window showing the manual, when this window is fully loaded click on the disk top left to save a copy to your computer for printing
http://home-solutions.hsn.com/hoover-12-amp-steamvac-powermax-carpet-cleaner_p-2750224_xp.aspx
Jul 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover powermax s3530 spitting out dust
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Apr 17, 2009 | Hoover Powermax S3530 Bagged Canister...
I can't seem to find the direction guide for my Hoover F6213-900 Steam Vac PowerMax TurboPOWER
It's on the Hoover website, I just looked it up.
www.hoover.com F6213900
Let me know if you need anything else.
Feb 01, 2009 | Hoover F6213-900 SteamVac Agility...
Received hoover powermax fusion vac today and the handle will not go down as indicated in diagram.
What is your model number? A Savvy and Powermax are differntent models. The Savvy the handle slides on and there are 4 screws to hold it in place. The Powermax has 2 screws to hold it in place. have you removed them before trying to put the handle on. If you have, you just have to work so it will slide down then put in the screws to secure it.
Apr 22, 2008 | Vacuums
LOUD NOISE FROM HOOVER POWERMAX ii
These vacs can stop up in almost inaccessible places. That sound means that it has stopped up somewhere and the electric motor is in a strain. Keep it running like that long enough and the motor is toast. I have one that seems to prefer the hose area where it goes by the motor and into the bag. The tube from the motor to the bag also is prone to stop up. To take these apart requires that you start at the beater bar area and work you way inward. In certain areas if you look closely, you'll see little arrows pointing to the screws. These are the ones that will allow you to get closer to the innards of these. When you get to where the motor is, look for blockages from the attachment hose. It takes only small items to completely block it off which will effect performance from both the beater bar/normal intake and also from use of the hose itself. The b***ards can be a pain to keep functional. I've personally removed rather sizeable wads of dog hair from mine that mucked up the works rather than went into the bag. Belts for the beater bar are notoriously short lived in these as well. When they break, the vacuum is only good as a floor sweeper. Stock up on both belts and bags for these. Good luck!
Oct 20, 2007 | Hoover Powermax U5242-930 Vacuum
Vacuums Logo
114 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
