How can solve mixing toner canon ir1600 - Office Equipment & Supplies
When ur machine make mixing toner check the sensiors
Posted on Dec 09, 2013
5 Suggested Answers
SOURCE: how can solve mixing toner canon ir2000...
Posted on Oct 21, 2010
checkitright
  • 1362 Answers
SOURCE: technical suport
Try checking the fuser section,
1- bad thermistor
2-bad thermofuse
3-bad fuser lamp
Posted on Aug 07, 2008
I have e000 message on my machine IR 1600
Posted on Dec 22, 2008
  • 92 Answers
SOURCE: how can I solve the problem E000 on canon ir1600
hello,you have a problem with the thermistor that check the temperature of the fixing unit ,must change the fixing unit and than must do a clear all on service mode.
Posted on Dec 27, 2008
Canon IR1600 problem light copy
Hello, Either toner cart. for fusing unit is bad. Here is website for manual download.
Canon imageCLASS D860 Basic Manual
Jul 03, 2014 | Canon imageCLASS D860 All-In-One Laser...
My canon ir1600 does not copy the output paper is white please advice
Take the toner package out, shake it, put it back.
Buy a new toner cartridge.
May 05, 2014 | Office Equipment & Supplies
Canon IR1600 Copier
what do you mean copy halfway only on the top of the paper or only on down side of the paper, or only on the left side or right side of the paper...are u using A4 paper..?
Dec 09, 2013 | Canon IR1600 230 VOLT 50/60HZ
I Just replaced the toner in my CANON IR1600 PHOTOCOPIER and now have the Error code E100. I put the old one back in to see if it was different but it still said E100. How can I fix this? Thanks
Hi carolyn ,
I am a professional canon service eng . My Name Is D K Kumar . e100 is not related to toner at all . it is the indication that the develper unit has not been detected . remove the left side cover . you will be able to see the top of the develpoer unit. On the left top portion of the developer unit u can see a white coloured accuvator . it is a small white plastic piece ..whhen the side door is closed te white piece should get pressed or should move forward . if the moving action is not happening then the m/c will give u E100 error. in your case the reasons /problem could be :
!) The spring connected to the white plastic accuvator is missing or spring action is not happening.
2) the white accuvator it self is broken or missing.
3) the plastic stick /piece which protudes from the side door and pushes the accuvator is broken.
4)lastly you have not closed the side door properly or not closed at all.
Carolyn if u r able to understand my above tips thn u can do it your self , if not call a your local canon enginer.
best of luck God Bless u
P.S. Carolyn if my solutions have helped u then i request u to kindly reply to me at my enail id: narkumar81@rediffmail.com
Apr 10, 2011 | Canon Office Equipment & Supplies
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Toner fixing massage
If you mean " toner mixing ", you should check the toner ( if the toner is hardened, replace toner) and toner unit, remove toner unit shake it ( verry well ). If you havve skills and good will, carefully dismantle the toner unit and vacume it, then put it back, put fresh toner and then after auto initialization when message "toner mixing" stops you can use it again.
If the copier was without toner for a long time yust let her do the toner mixing, eventually turn it off and on for better toner dosing.
Pls. rate
May 03, 2010 | Canon imageRUNNER 2000 Copier
Technical suport
1- bad thermistor
2-bad thermofuse
3-bad fuser lamp
Aug 07, 2008 | Office Equipment & Supplies
247 people viewed this question
jasbo
jasbo
