Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint AQGD169S flashing F5 machine blocked
    New Friend:
Mine said the same ive cleaned it out but when i took the back off ive noticed rusty coloured water comeing out of the back of the drum do you no what this may be as its not turning now
Posted on Sep 24, 2013
3 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: Hotpoint washine machine ERROR F5 machine blocked
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood. Alternatively bale out the sump under the main screen filter plate.
  3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked or restricted.
  4. Also check that the main waste drain pipe and one way valve to a sink waste connection if you use one, is not blocked and clean if required.
  5. Access the pump from under the lower rotor arm and protective grille and check that the impeller is free to move and is not clogged or restricted by debris or sludge. Clean as required.
  6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power. It is a good idea to take digital pictures of the pump assembly before attempting to work on it or remove it so that you can refer back to it when you reassemble the unit or replace it with a new unit at a later date / time.
8. Remove and check the electrical connections to the pump and make sure they are in good order.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage. If they are then clean them thoroughly.
10. Then remove the pump and check motor is OK and that the motor turns OK. Also check that the pump impeller vanes are in good order and not blocked. If necessary replace the pump with a new and identical unit.
11. Carefully reassemble the pump observing the correct placement of gaskets, seals, O Rings, hoses and securing straps, electrical wiring.
12. Reconnect the hoses and then reconnect power and switch the machine on.
Also see additional info to follow.
Posted on Nov 14, 2009
  • 193 Answers
SOURCE: fix my hotpoint aquarius aqgd169s uk
THAT BLOCK IS A COUNTER BALANCE DEVICE. IT SHOULD BE REPLACED
Posted on Oct 28, 2009
Hotpoint aqualtis aqgd169s
It seems most likely shorted somewhere in the wiring system and you have to check for every defective part ,use step by step method
Dec 10, 2013 | AEG Washing Machines
Hotpoint f5 machine is block
Possible fault with the controller unit
Check this link for tips to probe: controller unit
Nov 20, 2013 | Washing Machines
My washing machine keeps flashing F5... It works for the cycle but when it starts to get to the spinning process it flashes F5 and doesn't work
Sounds like a blocked pump, unfortunately unless you are very handy they make it impossible for you to do it as it involves leaning the machine back and taking off hoses etc and it can be tricky to get back on unless as I say you are a DIY'er.
Sep 05, 2011 | Hotpoint Washing Machines
Why is my washing machine flashing f5
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
F05 - Pressure switch jammed on full
All error codes at above link...
May 12, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius stopped working full of washing F5 showing on screen
hi im pretty sure f5 is pump blockage try filter on the front bottom right hand corner behind the kick plate if its not blocked it could be the level switch this is located under the lid its a round switch with a plastic tube going into it this could be faulty thankyou
Jan 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aqualtis - F5 was flashing on screen and all the icons ? Can you identify problem as I dont have a manual
Draining blockage. Lift the machine, you'll find a black tube under it. Carefully remove the tube, remove any garment that may have blocked it, clean the white ball thoroughly and pay attention to put it back exactly where it was. Put the parts back where they belong and try again. Good luck!
Jan 13, 2011 | Washing Machines
Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Jul 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Not spinning- F5 fault error Hotpoint Ultima
I HAVE A HOTPOINT AQXXD 169 PM WASHING MACHINE WE HAVE A FLASHING MESSAGE F5 WHAT IS F5 AND WHAT DO WE DO. IS IT IN THE INSTRUCTIONS SOMEWHERE??????? WHAT PAGE????
May 11, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
623 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
