Question about Sharp AR-M208N Copier
Sharp 10 error code u9-88 - Sharp AR-M208N Copier
How to correct error code 4 in 10 on Sharp pocket computer pc-1270
I found the answer for the PC1500, and I'm guessing the error codes for the PC1270 will be similar. Here is what the manual says:
This error occurs when there is no DATA corresponding to a READ command, for example:
10 READ X, Y
20 DATA 10
30 END
The display will say, "ERROR 4 IN 10"
The solution is to provide enough DATA to satisfy the READ. For example, change line 20 to read as follows:
20 DATA 10,15
Hope this helps.
May 04, 2017 | Sharp Office Equipment & Supplies
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
Error code c4-10
This code does not exist. C4-00 means your Primary Transfer Corona stick is bad and needs to be replaced.
Nov 20, 2013 | Sharp MX-3610N Color Photocopy, Print &...
SC L6-10 ON 5631
i have problem in my photo copier sharp ar203e the problem is op what mean?
Mar 22, 2013 | Sharp AR-M450N Copier
PLEASE, WHAT IS L2-10 ERROR CODE IN THE SHARP ARM-205? TKS. DARIO
Hi Dario, L2-10 Code is one i have never seen before, are you sure its correct?
Jul 12, 2011 | Sharp AR-M205 Copier
Error code u2-10 on a sharp mx2700n photocopier
U2-10 SRAM user authentication index check sum error. I know, gibberrish right? To clear this error, put the machine in "simulation mode" by pressing "c" "*" "p" "*". then type 16, press the copy button, then press "execute" then press "yes". Hit the "ca" button to go back to ready. This should clear the error code. If the code returns, then the PCU PWB board needs to be replaced. I hope this helps.
Jan 27, 2011 | Sharp MX-2700N Color Copier
Error code f9-10 and f6-80
while printing showing error 10
Mar 23, 2010 | Office Equipment & Supplies
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
Sharp AR C-330 Error Code E 710
E7-10 refers to black shading correction.
sometimes caused by a poor conection between the icu and the ccd. check ribben cables.
Nov 28, 2008 | Sharp AR-C270 Color Copier
Sharp AR-M208N Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
