Question about Microsoft Windows XP Home Edition
Hideing my i,p address
Hi is it possable to hide my i p address from outsiders to make my pc a bit safer. if so how can i do it iam not all that up on pcs but can find my way around most things on here thank for the help..
  • 728 Answers
Hi tony tiler,
If you are connected directly to the internet via a modem, is the only way the outsiders can see your IP. If you have a router or smart modem, then you are shielded from the outside. The router or Smart modem uses what they call NAT. NAT is a translater to all the devices that require an IP address. The process is sort of simple, your ISP or internet provider gives either an assigned IP number or a leased IP number, (meaning it dynamically changes every 24-48 hours) and the Router NAT function takes on that number to the outside, then it converts each device that is connected to it, to an internal (non-seen to the outside) number in the sequences of 192.168.1.###. ### could start at 1 and go to 255. Then when you send a email or when browsing the internet, everytime you send packettes of data back and forth the router knows what you sent, and when your reply comes back it remembers which internal device sent it and forwards that pack of data to that device. (or computer in a network environment)
If I've totally confused you, I'm sorry, but the jist of this is to get yourself a Router so you can be invisible to the outside. If your not sure whether your modem is smart or not, you can test it, by going to a command prompt. (click run, type CMD) then at the flashing cursor, type in "ipconfig" less the " symbols. Then it will show you what your IP address is. If it starts with a 192.168. type number vs. 62.925.##.### then it's a smart modem or router.
Router's range from very low cost of $20,00 to very expensive, for what you're trying to accomplish I wouldn't go to fancy on a router. I like Belkin routers, for their ease of use, basically plug it in and it works. No messing around with it. Or their popular ones like Dlink, or Linksys. They also have the wireless routers, so you can connect wireless laptops, wireless printers and so on.
Good Luck, and don't forget to leave a rating.
Thanks
Mark
Posted on Apr 23, 2009
Testimonial: "thank you very much for your time very helpfull"
  • 123 Answers
You can use a proxy - you connect to another computer which feeds your request.
But unless you pay for it is going to make your internet very slow.
  • 46 Answers
Http://anonymouse.org/ this is a free anonymizer does a decent job slows you down but routes you to mutiple points does more than a proxy a nat router will keep your local ip your machines (address ) hidden but your public ip (home) address is known. which can tell people alot about you.proxies are ok but it is only one point of protection between you and the internet a good anonymizer (also called web proxy) will bounce you a few times (open proxy) before you go to the public internet.don't confuse this with a caching proxy or a content filtering proxy.probably more info than you need hope it is helpful
    New Friend:
  • 113 Answers
You can use Proxys to hide your original I.P.
Take a trial for 14 days from the below mentioned website :
http://www.hide-my-ip.com/
Hide my ip
You can hide your ip address using this software http://free-hide-ip.en.softonic.com/
You can also use Proxy server to hide your ip.This could mask your IP with a fake one. You can check whether your original ip address hided or not using this site IP-Details.com
Dec 30, 2013 | Computers & Internet
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
Aug 27, 2013 | Computers & Internet
How do I change my I P address?
If you want to change your ip address during surfing on internet,simply use proxy sites or software's. It's really effective to change or hide your real ip address from public. Proxy sites normally served free of cost.But ip hide software's charged little amount.you can choose whatever you want.You must check your ip address when your are in anonymous surfing, for monitoring the proxy site or software working or not. You can get your ip details at Ip-Details.com
Apr 27, 2012 | Toshiba Computers & Internet
How can i make my ip address not shown
It is not possible to hide your IP address. Your external IP address is needed to allow traffic to the internet to get to and from you.
Within your local network, again the IP is necessary for traffic to get to and from you.
There is a lot more to it than that, but thats the basics.
Jan 23, 2011 | Computers & Internet
Help me to get hide ip-address,how to find ip-address?
Just Google 'Free proxy servers'....that will give you loads of links to hide your IP address.
The only way to find someones IP address is if they log-on to a site to which you are an Admin/Moderator.
Sep 15, 2009 | Computers & Internet
Want to hide my IP
Unfortunately, it is not technically possible to always hide the public IP address of a home network. An IP address enables devices to locate and communicate with each other on the Internet. Completely hiding the IP address of a device would render it invisible but also unusable online. On the other hand,
It is possible to hide public IP addreseses from most Internet servers in most situations. This method involves an Internet service called an anonymous proxy server.
May 31, 2009 | Transcend T.sonic 610 MP3 Player
Ip hiding
You can use any proxy website, there are tons of them out there if you search Google....
One that I like is http://www.hidemyass.com
Simply goto the site and enter in the address you are trying to go to, its that easy!
Sep 30, 2008 | Computers & Internet
How did i change the ip
Your internet service provider only able to change your external ip address. The only way to change it own by using proxy sites or ip hide software's. Online proxy sites are simple and free of cost . But they worked for some periods only. So you can always check your ip is hide or not at Ip-Details.com
some free online proxy sites
hidemyass.com
hidemyip.com
boomtunnel.org
anonymous.org
Jul 15, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Microsoft Windows XP Home Edition Logo
251 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
