Question about Kenmore Ovens
Model 79097603002 lower over does not work after self cleaning cycle. Error symbol appears to be over coil or element
SOURCE: "Door Locked" keeps flashing
Was able to get the lock to go in on the door and then turned off the power which reset the system.
Posted on Apr 01, 2008
Maytag317
  • 1136 Answers
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Posted on Jun 20, 2009
  • 3 Answers
SOURCE: The lower oven on the ECD230 does not heat. Most
I just got the same problem...but neither the bottom or top (broil) elements work. This started after a "clean" cycle.
Posted on Nov 26, 2009
  • 45 Answers
SOURCE: elements wont come on, although fan and preheat
Thermal fuse behind oven probably opened up.
Posted on Jan 25, 2010
  • 327 Answers
SOURCE: F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
Posted on Jun 01, 2010
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
GE stove model GRSR3620SM-2 Self Cleaning Cycle Not Working.
my first thought would be a loose connection at the element or main power terminal. it could be a relay board issue also
Jan 08, 2012 | GE Profile JTP18 Electric Single Oven
F9 Error during self cleaning cycle
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 31, 2010 | Ovens
Self Clean cycle on Hotpoint Gas range doesn't work
We see a symptom like this due to a failure in the control board. Although it usually also affects bake mode. Another cause could be a problem with the door lock as it must be engaged (by the controller) to initiate self-clean.
If this doesn't help, you can either post the full model number or email me at bruce@fixyourboard.com and we can dig deeper.
Oct 09, 2009 | Ovens
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Maytag electric oven - MER5770AAQ. lower heating element not work
Vic
Jun 20, 2009 | Ovens
Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Broil feature not working
make sure element is getting voltage (120v)
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
20 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
