Question about Hardware & Accessories
Hi , i wondered if anyone can help me? I have recently purchased a 12v 3 minute delay off timer, I am trying to rig it up to my waterpump which pumps the water around my camper for the webasto night heater. Basically i want it to carry on running the water pump for 3mins after i have turned the night heater off. The delay timer i have puchased is a fuji ST3PF delay off 8 pin timer. The diagram on the side of it states terminals 2 and 7 input(doesnt state which side is positive and negative) terminal 8 com terminal 6 normally open terminal 5 normally closed treminal 3 says connection above it and shows a link to terminal 4 with the word reset printed in the middle of the linking line. Can anyone please tell me which wires i connect to where, as iv been pulling my hair out trying to fathom out what goes where n im now completely bald. Any help is much appriciated. i have only basic knowledge of 12v electric and relays so nothing to technical please thanks steve
Hello, Having the same power supply voltage to the coil of the relay, pin 7, and also the thing you want to stay on for more seconds, pin 8, will not work. When you kill the power to the relay the other thing will go off right away as well and a few seconds later, you will hear the relay switch. I made a diagram to show how it works to have a solenoid valve close 30 seconds after the water pumps stops. This is to let the water slow down before the valve closes to prevent water hammering.o,
Hi , i wondered if anyone can help me? I have - wondered-anyone-help-me-dngbouuf0xnewoajm5wetpwu-5-0.jpg
Posted on Jan 23, 2015
3 Suggested Answers
SOURCE: I have a Et 70115C
A) 5 terminal ET70115C.
Voltage selector set to 240.
B) BUT you say you have 120Volts from breaker >>> confusing, so I'm proceeding on basis that you meant to say 240V from breaker.
Add a comment at any time.
C) Review timer:
5-terminal ET70115 timer has NO and NC terminals
NC is normally closed >> this terminal has power when timer is OFF
NO is normally open >> this terminals has power when timer turns ON
For water heater, you want NO terminal 4 so water heater turns ON when timer turns ON
D) Wire for 240Volt water heater
Two hot wires from breaker connect to terminals 1 and 2. This powers timer clock.
Jumper wire connects between terminal 2 to terminal 3. This sends power to the switch circuit.
Wires to water heater connect to terminals 1 and 4
E) 5-terminal timer turns off 1 hot wire to 240V water heater.
Turning off 1 hot wire will stop 240V circuit from working; Water heater thermostats also turn off one hot wire.
240V water heater has black and red wire.
Wire from terminal 4 should connect to Black wire on water heater.
Diagram shows two wires on terminal 1
Two wires on terminal 2
One jumper wire on terminal 3
One wire on terminal 4
Zero wires on terminal 5
Posted on Dec 03, 2010
  • 5245 Answers
SOURCE: I am having trouble wiring a 120V time delay relay. Any help would be greatly appreciated.
You have 120Volt 8-pin off-delay timer.
When you put power to terminals 2 and 7, test which other pins are energized.
120Volt Black Hot wire usually goes to terminal 7 and Neutral white wire goes to terminal 2.
As general rule the other terminals are dry and receive no voltage when timer is energized at terminals 7 and 2.
This means you must add a jumper wire from your Hot wire on terminal 7 to the Com terminal 8. This action will energize both Com terminal 8 and NC terminal 5. So test if 5 and 8 have continuity when timer is off. And test if both are powered when Com terminal is energized.
Then when timer activates, NC terminal 5 will no longer receive power from Come terminal, and NO terminal 6 receives power instead.
Copy following link for general illustrations that may apply to your timer and application:
http://waterheatertimer.org/How-to-wire-pin-timers.html
Posted on Aug 05, 2012
Amount of labor involved in replacing water pump in dodge ram 1500
For the water pump at a pro shop 2.3-3 hours max.diy on waterpump factor in another hour or.two if u have to rig or go buy a tool for fan removal rusted or.broken bolts ect ect For the belt only 30 minutes for a diy with basic skills and hand tools.
Dec 04, 2013 | 1997 Dodge Ram 1500 Truck Serpentine Belt...
I have a horn that sounds when my hay baler chamber is full. I am looking for a timer relay that will allow the horn to sound for 3 to 5 seconds and then disconect the circuit so it won't drive me...
DEI 528T appears to be 12Volt 'wait to start' or ON-delay timer.
528 receives electrical signal, and then delays the start-circuit by up to 60 seconds.
For example home alarm system. Door is opened and alarm sounds. Install DEI 528 and set for 60 seconds: Door is opened and alarm will not sound for 60 seconds.
You need 12-volt off-delay timer.
Off-delay timer receives electrical impulse, and then begins a countdown.
After countdown expires, then circuit turns off.
ELK-960 appears to have off-delay feature for 12V DC
http://www.homesecuritystore.com/p-423-elk-960-delay-timer-module.aspx
Use wiring diagram #7 for alarm cut-off:
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ELK-960_Install.pdf
Aug 25, 2011 | Directed Electronics Dei 528t Pulse Timer...
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
I am in need of some advise. I have a pellet stove and need to replace an obselete part, I am wondering what would be the best delay relay timer to use, it will operate an 6rpm/150lb torque auger that goes...
1) Pex supply sell the E502 OFF delay Paragon product: Timing cycle begins when switch is activated, and shuts down at end of timing cycle. 5 seconds to 3 hours
http://www.pexsupply.com/Paragon-E502-Electronic-Off-Delay-Timer-5-sec-to-3-Hrs
http://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hb
See manuals for Paragon product:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#percentage
2) Tork ACT120 cycle timer (minimum ON is 30 seconds)
http://www.grainger.com/Grainger/TORK-Adjustable-Cycle-Timer-4JNH8?Pid=search
http://www.nsi-sales.com/act_series.htm
See ACT manuals:
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
3) Intermatic CT1000 cycle timer: cycle durations of 30 seconds to 30 minutes, with on-off durations from 1 minute to 29 minutes.
Click model number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/percentage%20cycle%20timers.aspx
Drillspot sells indoor/outdoor 120V or 240V CT1000
http://www.drillspot.com/products/1325934/Cycle_Timer_CT1000_Cycle_Timer?s=1
4) Do a google search for 'electronic cycle timer' or 'percentage timer'
5) Timers listed above can be wired to a contactor (or relay) that turns on auger, if that's what project calls for.
Dayton off-delay timers require push-button operation
Feb 03, 2011 | Amperite Dayton Solid State Timer On Delay...
Vent axia SOLO PLUS SELV T fan has a delay timer fault
There is usually two pre sets; one for time delay before turning on and one for how long it runs for. Have a look
Sep 14, 2017 | Dryers
Changing waterpump
Intrepid 3.5l is behind the front cover. Not fun, but can be done.
May 01, 2009 | Dodge Intrepid Cars & Trucks
How do I use 360' lens on my Canon G9?
The C1 & C2 settings are for "Custom" settings. You'll most likely want to set your camera either to "P" or "Auto" mode.
To have it delay for 10 seconds and take 3 shots, press the "Menu" button and then scroll down to "Drive Settings". Then, choose the following settings:
Self-Timer: "C" Delay: 10 sec. Shots: 3 shots
Then, press the "Func./Set" key to lock in the change. Next, press the custom timer button on the back of the camera and then choose the "C" timer using the directional keys. Then, press teh "Func.Set" button.
Lastly, set up your camera, press the shutter release, and the timer light should start blinking. 10 seconds later, the camera will take 3 photos in succession.
Hope this helps!
Mar 10, 2009 | Canon PowerShot G9 Digital Camera
Kitchenaid KAWS750JQ3 Top Load Washer
hi there,
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
thanks
Sep 28, 2008 | KitchenAid KAWS750L Top Load Washer
Waterpump won't pump and spin cycle won't start.
one of 2 things are happpening iether hte timer is not sending down the power to operate the pump , or switch is not closing correctly to allow power to the pump
Mar 19, 2008 | Frigidaire FWS833A Top Load Washer
Hardware & Accessories Logo
361 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
