Question about Kenmore Dryers
Loud click and buzz then does not start lid does not lock when it does this. It works some of the times
  • 2 more comments
  • Brett Oct 16, 2013
    diagnostics never would give me much info. I took the switch apart the spring and clip where out of wack.. I put it back like i thought it should be and it working we will see. I don't think it ever worked correctly as it would always lock down and never release the lid until after the full cycle. Now it will release on pause. we will see as it has work intermittently thaks for the help
  • Sal DeAngelo Oct 16, 2013
    no problem glad you got it to work
    i just got your other message and it's not working again,if you took the switch apart and it did work i'd have to say you still have a bad lid switch,this is where i would start,also tilt the washer back and remove the felt and plastic cover on the bottom,have someone hit the start button while you're under the washer and see if you can hear where the sound is coming from,also the lid switch is used as a safety so nobody can open the washer when it's running,if the switch is bad it won't run.
  • Brett Dec 02, 2013
    im still desiding of its worth another 139.00 for a washer that washes with air instead of water lol..
  • Kenmore Master
  • 2,128 Answers
What's the model number.if you hold in the door switch by hand will it statrt?
Posted on Oct 13, 2013
Testimonial: "this was ported in wrong section it has been reposted in washers"
  • 40 more comments
  • Sal DeAngelo Oct 14, 2013
    what's the brand name and model number, of the washer
  • Brett Oct 15, 2013
    Kenmore top loading washing machine model # 110 26002010
    no the switch on the body cannot be overrided with out taking the top off
  • Sal DeAngelo Oct 15, 2013
    get a putty knife and stick it in between the top and front panels,there are clips one on each side,when you get the top up,reach down on the left side of the front panel,there's a tech sheet or booklet there,it will tell you how to put it into diagnostics,i've found with this washer that there's an actuator part number W10006355 that fails,unplug it,tilt the washer back,remove the bottom felt panel,you'll see a white cover,,two 5/16 inch screws hold the cover on,you'll see the actuator or shifter,two phillips screws hold it in place,go here,it shows you what to do but just lean the top against the wall so you don't have to lay the washer down,also check the nut on the white gear,i've seen that get loose too.the best thing to do is put it into diagnostics,find out the error codes and go from therehttp://www.youtube.com/watch?v=8Z1JdsJYa...
    http://www.youtube.com/watch?v=ObQSoeoae...
    these are the common kenmore whirlpool washer diagnostics
    lid switch part number W10404050
    http://youtu.be/chNNoptT8nE this is my model not at wirlpool copy i do not believe no lights for dianostics it will click and then produce a loud buz the lid lock button will stay red and machine will do nothing until you unplug it. plug it back in anbd it may or may not work if it doesnt it will do the ssame thing (click and Buz)
    http://www.repairclinic.com/PartDetail/S...
    ok I finally got into diagnostic mode it will not run a wash or spin test but will run water and drain the whole time the lid lock buttlon flashes red I will order a switcvh for it as a first try it does not click and hum in test mode nor will it complete a automatic test cycle
    go here and watch the video,you could have a loose nut on the white gear that you'll see in the picture.i think to get this into diagnostics turn the selector knob once to the left,then three to the right one to the left and then once again to the right,now turn the knob clockwise until just the done light is lit,hit start and turn it clockwise again and the error codes will come up.the tech sheet might be in the top console or on the inside front panel.this video will show you how to change the shifter or actuator.let me know if this helps you,the best way that i can help you is if you find any error codes,that grinding sound sounds like the nut on the bottom could be loose,if it's not i'd change out the actuator,these are the two most common problems with this style washerhttp://www.youtube.com/watch?v=0zmzSSUc8dI.
    if you order the parts from repair clinic they let you return any parts you buy and you have 365 days to do this,not a bad deal
    decided to take off the top but the clips are in a difernet position than videos I am at loss to trying to undo them ther seems to be one in the middle front and 1 inch in on the left and tight a putty knife will not budge them
    I would like to just bypass it as the washer is notorous for not having enough water in the cycle. to HE for me.. I like clean clothe and them coming out of the washer dry alrready is been a conastant issue since it was first put in use a real bummer of a machine
    it's been a while since i saw your model,i think i had the same problem,i removed two screws from the back there's like a hinge back there and i slide the whole top forwards to get the top up,also i worked on a centennial,on the top lid there's two screws that holds the part that connects to the lid switch,it's just a piece of metal in the clip that makes the magnet in the lid switch work,i removed it and just stuck it into the bottom part of the switch so you can open the lid without disturbing the lid switch.this way if you want to add water or more clothes you don't have to wait for the stupid lid switch to open,man is that a bummer waiting.hope this helps.
    let me know if you get it into diagnostics and if you pull up any error codes.
    diagnostics never would give me much info. I took the switch apart the spring and clip where out of wack.. I put it back like i thought it should be and it working we will see. I don't think it ever worked correctly as it would always lock down and never release the lid until after the full cycle. Now it will release on pause. we will see as it has work intermittently thanks for the help
    well that lasted for 2 loads.. the loud buzz comes fron unerneath or in the control panel it will buzz the lock or buzz and not lock you can here a very distinct click when it locks other wise it just buzzes. I guess i will try a new switch but i have my wonders if the buzz is more of the culprit.
    i had one of these washers,it was buzzing,i tilted it back and felt the pump and this is where the noise was coming from,i took down the pump and found a sock stuck in it,or like i told you one of the biggest problems with these washers is the actuator or shifter same part or the nut gets loose on the white gear on the bottom,all you have to do is remove the bottom felt panel and take out the two 5/16 inch screws that hold the plastic cover in place,if you find oil down there you could have a bad tranny. but hopefully you just have a bad lid switch.also like i told you you can remove the strike off of the lid and stick it into the lid switch so you can open the lid whenever you want,it's just two screws holding the strike in place.good luck if you need any help let me know.
  • Brett Oct 21, 2013
    ok but in a new switch it ran through to the spin cycle finished it when it started to fill with water the click and hum went off anain the hum stayed on and the thing smelled smoky it upluged it. I know get the same issues as before the loud click and hum but the hum shuts off after 2-3 seconds it sonds like abig magnet or a cylinoid malfuntions if i leave it unpluged for an hour or so it will get past the first trouble and fail at the refil after spinning. I have never been able to get it to run the diad. becouse of the the lid lock buzzy and click hum stopps the diag.
    could it be thishttp://www.searspartsdirect.com/partsdir...
    or the acutaator like you said jsut doesnt seem like the noise it coming from the bottom but i am single nad have no way to turn on and get under it at the same time
    i dont think the machine is worth these parts lol but i will try the very loud click and hum has me stumped
  • Sal DeAngelo Oct 21, 2013
    put it just on cold water and see if it fills,you could have a bad water valve,after the spin cycle the washer just fills with cold water so the clothes don't rinkle and if the valve is clgged or no water going through the valve it will buzz or hum.youcan shut the water down,mark and remove the water lines and check the screens in the valve to see if it's clogged with sediment.if this isn't it i would call someone in to check it if you smell smoke.
    this has nothing to do with the lid locking,the cap is just for the motor,can you tell where the smell is coming from?if the motor isn't running you can check the cap.tilt the machine back and look at it,if the cap is bad you'll smell it and it most likely will be blown apart or look burnt,if the smell is coming from the top console you could have a cooked computer board but without being there i'm just guessing
  • Brett Oct 22, 2013
    it smell of smoke after the humm stays on and doest shut down after a loud click im not afraid of the smoke im fight here wathching it its only a year old and only had 15 loads ran through it was so horible we never liked it so we just kept using the old one now the old out two.. lol
    I just have to find what humming sounds like a magnet click and a hum from a coil
    where its coming from.. i could replace all these part then still have to buy a new control board
    it broke a week after the warrentee wwas out
    finally got a automatice diag to run test codes all point to a bad lid lock cylinoid..
    so that points to the main control panel.. 136 at sears 217 most other places but i still don't know where the heck the loud hum is cominmg from.. and why.. thanks sal for your interest and help
  • Sal DeAngelo Oct 22, 2013
    let me know how you make out,did you check the cold water and the valve is working correctly?also i would try to run it in diagnostics again and check the error codes,this will point you in the right direction on where the problem is,one more thing if i were you i would unplug the washer tilt it back and on the back right side you'll see the pump,there are three screws that hold it on and is very easy to take off and check to see if anything is stuck there before you buy the board.good luck and let me know what you find.
  • Brett Oct 23, 2013
    ran fine so did auto and all manual..now I think it may be the capacitor or acuator the run sometimes other not make alot of noise.
    noise only when they dont work sound fine when they do
  • Sal DeAngelo Oct 23, 2013
    if the cap blew the motor wouldn't run so like i told you before the two most common problems with these washers is the actuator or the nut gets loose on the gear on the bottom near the actuator.
  • Brett Oct 24, 2013
    well I didnt understand what you meant by a cap.. so if it is the actuator it must have memory cus when you unplug the machine for 4 hrs it will run fine for a few cycles then do it again. it does not come up as an issue in diag because it anly happens of firsts start after running a few loads stopping the diag from running or giving a switch lock error
  • Sal DeAngelo Oct 24, 2013
    the cap is the capacitor and the actuator doesn't have any memory but if the actuator fails the washer will not run correctly it's used to shift or engage the transmission
    http://www.youtube.com/watch?v=yTHryoT78...
    Finnaly figured out that all the test were not running as i needed to manually test the lid lock and leave in lock mode then run the other tests, it came back F1 E2 wich is motor control fault so i test the shifter manually it could not complete test and buzzed and locked out. Part ordered.. we will see the only thing else now is the main control . Thank you...
    let me know how you make out in case someone else has same problem maybe this can help them too.
  • Brett Oct 26, 2013
    part installed.. same issue on to the main elec control... I hate wirlpool nothing but junk. Like i said before this thing has about 20-25 loads ran through it...
  • Sal DeAngelo Oct 26, 2013
    sorry to hear it,i know you don't want to hear this but you changed the two cheapest parts that this washer has had problems with,if the buzzing was coming from the shifter or acuator same thing then i would have changed it out.now you have to decide if you want to spend the money on the board or a new washer,try this,call the manufacturer,tell them you're having problems with the washer and the computer board isn't working correctly what can you do for me,they might give you the board.i wouldn't tell them that you changed any parts,they might say you caused the problem,all they can do is say no,good luck with your washer
My washer makes a loud buzzing noise model Fridgidaire GLTF2940FE
Good Afternoon Friend,
I understand that your Frigidaire washer, model# GLTF2940FE, will lock the door, start buzzing, and not start the cycle. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 26, 2014 | Frigidaire Washing Machines
I have a Maytag A183 top loading washing machine. It recently starting making a loud buzzing noise when you first pull out the knob to start it. If you turn it off and on a couple of times, the sounds...
That loud buzzing noise is your water fill valve. First turn off the water valves to the washer and unscrew the hoses and check that the filters are not corroded or clogged. I had a maytag washer that was doing the same thing and finally the lid switch and timer had to be replaced. I would unplug the washer and remove the screws along the upper rear cover behind the timer assembly and check that all connections are secure. Unplug them then plug back in if neccessary. Then put the cover back on plug back in and try it.
If it still does it you might need the water valve replaced.
Mar 13, 2011 | Washing Machines
Series 90 with loud buzzing/grinding noise, won't spin
It could have gone out of balance. See if the drum looks off center and center it if necessary. Turn it off and back on to reset the switch. If that doesn't work, try pressing on the lid either 2/3 of the way back on the right or all the way back on the left (depends on the model -- try both) and see if it starts. If it does, I would suspect the lid switch.
Jul 21, 2010 | Kenmore Washing Machines
Whirlpool cabrio-buzzing noise when water runs
i think the problem that you have is one of the electric coils from the entrance valve from water. Check if there the vibration comes from there.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud buzzing noise
Mine is loud also when playing games. When playing DVD's it is not. I think it is a factory defect on some of the systems. I would not attempt to pull apart the DVD drive and try and fix it. It is working and on an XBOX 360 you should feel lucky that it is.
Aug 18, 2009 | Microsoft Xbox 360 Console
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
2005 Jeep Grand Cherokee Problem
I would start by checking all the fuses under the hood.
There is a fuse called IOD which the factory leaves out and gets put in at the dealer.
That fuse could be bad.
Oct 10, 2008 | 2004 Jeep Grand Cherokee
Grill buzzing
No, a buzzing noise merely means that something is vibrating from the magnetic field that is created when power flows through the heating elements. As long as nothing is obviously loose, the grill is safe to use.
Jun 11, 2008 | George Foreman G5 Indoor Grill
Dryers Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
