Question about Plumbing
My cutters don't lock on to the pipe when tighting down on pipe wheeler #90750 they seemed stripped is there anything other than buy new one some kind of replacement kit for the quick realese anything
  • Rod Davies May 11, 2010
    What kind of cutter - one which automatically cuts or one which has a knob to turn and tighten to the pipe
    If you have to buy new - get a "Pipeslice" not cheap but replacement cutting wheels can be replaced-almost and plumbers merchants
    Problem Solver:
  • 17 Answers
I am not sure what brand that is but I have been plumbing for over 20 years and still use the origanal set of cutters I started with. They have been rebuilt many time so parts should not be hard to get.
Posted on Jun 11, 2009
How can I replace this tablet's screen?
Yes. You'll have to purchase some window screening material, the locking strip for holding it in, and the tool for inserting the locking strip. You can get materials like this at Lowes or Home Depot or any hardware store. When you go to buy your material take a piece of the old locking strip along so you can match it to the lock strip you want to buy. The tool is only a few bucks, and you'll need a putty knife (plastic works best). You will reuse the old frame for the screen, so if it's bent, make sure to straighten it first.
Here's a video that shows you how to replace it.
One thing to remember is don't stretch it very tight. Once you have the new screen tucked in, the frame should lay flat; if it doesn't, it's too tight.
Sep 05, 2015 | Tablets & eReaders
Can I replace just the blade on my pizza cutter? It seems a shame to buy a new one as it really is in good condition, just the blade is blunt.
The Web Restaurant Store sells pizza cutter blades for a good price, although as the pizza cutters themselves are not expensive, you might find it just easier to buy a new one.
http://www.webstaurantstore.com/american-metalcraft-pcw-4-4-pizza-cutter-replacement-blade/69332864.html
Feb 28, 2013 | Home
Do a 2007 suzuki four wheeler LT-A400/F have a fuel pump?
make sure the carbeurator's low jet is working properly and not clogged
Nov 11, 2017 | Suzuki GT 380 Motorcycles
My needle won't go all the way down, it seem the side adjuster seem very tight. it was working but now it will only go all the way down when the bobbin case is removed. how do I fix this problem?
It may sound like a silly question,BUT is ur wheel not tightend down to the sew settings? Make sure you NEVER turn that wheel backwards to much.It will strip the gears.Is ur'Bobbin inserted right?I can't think of anything else.SORRY
Dec 26, 2011 | Singer 3116 Simple
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
I need to know how to fix my brake line for a 1999 buik lesabre limited edition
I recommend getting a Haynes manual to follow when doing this repair (if you are going to do it on your own). These manuals have pictures, and very thorough instructions for repairs such as this, along with safety guidelines to make sure you are doing it properly. It will help you avoid mistakes and keep you safe on the road. I'll include a brief description of how to fix a break line, but I will probably forget to write something here, ad I don't want you to get hurt because I forgot to put in some piece of information -- so please buy the manual to make sure I have given you good information.
1. You'll need a pipe-cutter, a pipe bending tool and a pipe-flanger to do the job 2. Find the break line that is causing the problem and trace it from the breaks to the break Master cylinder. 3. Take a piece of steel pipe (standard break line) and use the pipe-bending tool to shape it to look exactly like the pipe you are replacing and use the pipe cutter to cut it to length (if you don't use a bending tool or a pipe cutter, you can cause a crimp in the line and your breaks will not work) 4. If you are replacing the entire line (recommended) remove the line from the breaks and drain off the fluid. 5. Flange (widen the pipe end) your break line at the end closest to the breaks so that it fits over the connector (like the previous break line was). 6. Connect the new break line to the breaks using a new connector (same type as the previous break line. Make sure that the rest of the break line is supported near the original line to keep from ruining the new line -- if it bends or crimps your breaks may not work. 7. Remove the old line from the mounting brackets one at a time, and replace it with the new one as you make your way up the line to the front of the car. Doing this one bracket at a time will help you make sure you are mounting it properly, and gives you a chance to inspect the mounting brackets as you go. If a bracket is bad (and won't secure the line) replace the bracket with a new one -- you don't want your new break line falling down and getting ripped off your car when you hit a pothole. 8. Once you get the line mounted all the way to the master cylinder, complete the removal of the old line, and attach the new one like you did at the breaks-end of the line. 9. Double-check all of your connections and make sure the mounting brackets are all tight, then bleed the break line to remove the air. (it's probably best to bleed ALL of the break lines to make sure you have not introduced a bubble anywhere -- this can keep your breaks from working properly) 10. Once the lines are bled, and everything seems to be in order, jump in the car and hit the breaks REALLY hard -- like you are slamming your breaks to save your life. Check the lines again to make sure they did not leak anywhere (especially at your connections where you had to flange the pipe). If there are no leaks, you should be good to go. If there is even a small leak anywhere in the line or at your connections you should go over the connections again to make sure they are secure. Once you have your lines tight, bled and have double checked that you can slam the breaks without causing a leak, you should be good to go.
I do not recommend doing this work yourself -- it is very difficult to do without a professional lift (as you will need space to work and jack stands don't give you much room). It is also a VITAL part to the safety of everyone in the car ... and if you don't have a lot of experience it is easy to miss something and put yourself at risk. A professional shop and get this job done in a lot less time, and with a lot less risk than an at-home mechanic, so it is probably worth the price. As I said before, the 10 steps above are a GENERAL OVERVIEW of the process -- not an exact science to follow -- I probably forgot to put some information there ... so PLEASE (if you are going to do the work yourself) get a manual to be sure you have all of the steps correct. I HIGHLY recommend that you take it to a mechanic, though (I do a lot of my own car repairs, but I don't trust myself with the break lines -- they are too vital to my safety ... and a pain in the neck to replace without the right equipment)
May 29, 2011 | Buick LeSabre Cars & Trucks
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
Pipe cutter is crushing the asbestoes cement pipe
I think you are supposed to rotate the cutter around the pipe. If this is so then use a small amount of pressure and then rotate, repeat until pipe is cut.
The cutters could be blunt in which case they must be replaced.
Mar 05, 2009 | Wheeler Rex Pipe Cutter No.29908
Plumbing Logo
62 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
