Question about Philips 55PP9401 55" Rear Projection Television
Philips 55PP9401 55 in. Rear Projection
I have a Philips 55PP9401 55 in. Rear Projection TV, but hsve lost the remote control. Is there a way to run the intellisense function so that I can correct the picture?
  • kcb14214 Dec 01, 2007
    Need to order new remote so I can run intellisense.
  • Anonymous Nov 26, 2008
    I have Philips 55PP9401 and need to run the intellisense but do not have the original remote. Can this be run some other way?
    Genius:
  • 1,694 Answers
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Posted on Nov 26, 2007
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=55PP9401&slg=en&scy=US
PDF download of your Owners' manual:
http://download.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at http://www.philips.com
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
I own a 60PP9401 60 in. Rear projection tv. My red convergance was way out of line. I placed tv in the shop a while back,cost me $300 to get it fixed! Got set home, red still out of line,but not as bad. My...
This set has an advanced menu for adjusting the convergence and what may have happened is the shop adjusted it (It is done with an original Philips remote) and then not SAVED THE ADJUSTMENTS INTO THE SET'S MEMORY.
I can if you have the remote get into the menu and adjust and SAVE the adjustments. If the set is HD the convergence will have to be adjusted two times, once in regular and once in HD.
Let me know if you have questions.
SD TECH
Jan 10, 2011 | Philips 60PP9401 60" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
I got this 60 inch projection tv for Christmas, it was used but works great, problem is owner lost the remote and manuel. I can use a universal but cant access all the functions or even change contrast or...
go to www.tvrepairworld.com and give them a call they will have the remotes for your model that do control all the functions and it wont need any reprograming since its made for your specific model tv.
Jan 07, 2010 | Philips Magnavox 9P6034C 60" Rear...
Intellisense button
If the model number on the set is 55PP9401/55 you have an interesting set----this model says Philips but was made by Hitachi---they made them for Philips for one year while Philips was gearing up to produce their own sets---very good set and is better than the Philips sets that came after it.
It uses (if it is this model) two STK-392-110 CONVERGENCE IC's----both need to be replaced and the set adjusted---no need for an original remote---with the set engaged in the convergence adjustment mode( there is a micro switch on the front of the main circuit board) A HITACHI REMOTE CAN THEN BE USED TO ADJUST THE CONVERGENCE. Hope this was helpful.
Aug 11, 2009 | Philips 55PP9401 55" Rear Projection...
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
Lost remote
Philips makes several universal remotes that are sold by stores like Walmart and Target. Look for one that has a menu button so you can access all the functions of your TV. You may not even have to program the remote if its made by Philips.
michtech
Feb 16, 2009 | Philips 60P8341 60" Rear Projection...
Using Intellisense without remote
some of the universal remotes by phillips have but not all have the program inside the remote for it u have to look on the box u can allso call magnavox witch is the same thing and ask customer service if the have a universal remote that will do that for u i hope this hp some
Sep 08, 2008 | Philips 55PP9401 55" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
478 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
