Question about Kitchen Ranges
Jsp26gp model ge range
Oven sensor is bad
SOURCE: Oven Temperature Sensor
it's just not just the sensor ,it's the thermostat which is on the back of oven knob. that sensor is part of the thermostat it's all one of the same part. to check the temperature put a thermometer inside the oven and set the the oven knob at 200 degrees. 20 minutes later check and see what temperature it's inside the oven, to regulate the temperature many of the new ovens are set from the factory, It can not be calibrate, on the older ones the adjustment screw is inside the shaft when you take the oven knob of, it's inside the shaft.
Posted on Dec 07, 2008
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
  • 89 Answers
SOURCE: GE gas range model JGBS10BEH2BB oven and broiler
you need to check the ignitor even if the ignitor glows it might not be pulling enough amps to call for gas replace the ignitor and this should take care of the problem
Posted on Aug 28, 2009
MNTECH
  • 1543 Answers
SOURCE: My GE range and oven won't go on but the oven
Sounds like you are only getting 120 volts to the range. If your house has fuses, check for one of the 50 amp ones out. Best if you have a way of testing voltage. Could be a loose / poor electrical connection at the range power recepticle where the cord plugs in, or where the cord connects to the range. Of course it could be in the range wiring or possibly in the range control, but that is not as likely. Get a voltage meter and find out where you are loosing the other half of your 240 volts.
Posted on Sep 06, 2009
SOURCE: GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Posted on Jan 12, 2010
JSP26GP code f3 then f2
What is the complete model number of the unit?
Dec 08, 2012 | GE Kitchen Ranges
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
Heartland metro f2 error code
bad sensor or bad computer board or clock assy.read out the sensor and find the tech sheet for your stove and it will tell you what the sensor should read out on,if the sensor is good then you have a bad computer board or clock assy.you can look up the error codes on the tech sheet too,look on the back of the stove,the papers are usually there on the back of the top console.F2 Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature
Nov 08, 2011 | Kitchen Ranges
Drop in kenmore range cuts off after a minute and F-2 or F-3 comes up on display.
The F2 code means that the oven overheated by at least 100degrees(a bad sensor will cause that)
the F3 means that the oven sensor is shorted,so both of them are consistiant with defective oven tempature sensor and the sensor should be replaced.
It is located in the oven baking chamber and can be replaced by unscrewing the screws from the bracket at the end of,pull it out unplug it,then reverse that process to install the new one.
With 2 different codes pointing to a bad sensor its apretty safe bets its bad.
GENE
Oct 12, 2011 | Kitchen Ranges
GE OVEN THROWS F2 AND F3 CODES SOME TIMES WORKS FOR 45 MINUTES BEFORE CODE
GENE
Oct 10, 2011 | Ovens
We have a GE oven model jms08bw2wh. The oven was working great now it seems like it is stuck cooking at 500 degrees no matter what the setting is. Any idea what the cause might be?
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | GE Spacemaker JMP28 Electric Kitchen Range
I had F3 and F2 errors and now the oven will not heat at all. It tries and then shuts off.
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
I have service manuals and MORE here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 19, 2011 | Ovens
Kenmore Mod.# 75824 I have a Fault Code EO-F3- the oven does not come on. No time display. I've reset the breaker and pushed the cancel/off button no help. This occured during a power outage.
Shorted sensor. Unplug the sensor and check it between each prong and the frame. If you get continuity you have a bad sensor. If the sensor is good, the wiring or the oven control is bad. The oven control has got to have a good sensor so it can know the temp inside the oven.
Jul 12, 2010 | Kenmore Ovens
My oven preheat light won't go off even after the electric oven has been on for a long time. Do I need a new oven? It is an older model GE.
you have a bad sensor or control panel. I would change the sensor first. it is the more likely culprit and is much cheaper then the control panel
Apr 23, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
