Question about GE Washing Machines
Water pours out the bottom of machine during cycle
Water pours out the bottom of machine during the washing cycle.
GENERAL ELECTRIC MODEL WWA8350G WASHING MACHINE - -was hoping to get a parts diagram before I go inside to find what the problem was - -a new washer? or a new machine...?
  • 70 Answers
Don't get rid of that machine. Those can last 30 years easily, and the stuff you get today cannot compare. You got a bad seal going from the basket to the outside tub. If left go, the motor eventually will short out. You will need to remove the adgitator first, by pulling up hard on it. Then grease the spline before you put it back. A 13mm metric socket (12 point) to take out the bolts holding down the basket. That rubber boot you will see in there is about 12" inches across at the bottom, and about 8" at the top, and looks like that funny hat Goober used to wear on Andy Griffith. The bottom band goes to the tub bottom, and the top goes up against the transmission. The clamps are reuseable, and the boot should be less than $30.00.
Posted on Apr 24, 2009
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
WHDSR209DAWW washer leaks major water during the wash cycle. Rinse and spin cycle fine, only pours water during the wash cycle. Kitchen was flooded from this happeneing yesterday. Took the covers off, all...
I asked my wife about this question, before I became to technical and scared you more then you needed to be scared. My DARLING wife told me right away that you are overloading your machine. It occured to me she may have done this a few times herself. Mind you this is 50 years of experience . When you load your machine with to many items the water is displaced and has to go somewhere, it's caming up over the top and causeing your flooding problem. After you clean up and have a few highballs to settle your nerves, you should be OK. My wife and I wish you GOOD LUCK.
Sep 24, 2011 | General Electric WHDSR209DWW Top Load...
Water will not fill during rinse cycle. it does fill when i start the machine but not during rinse cycle.
The rinse cycle only takes cold water so I suspect that you have a bad or maybe clogged water valve on the cold side of valve.hope this helps.
May 29, 2011 | General Electric WBSR3140GWW Top Load...
I have a GE model number WHDSR109J8WW washing machine. It works well, but there is a metal on metal squealing sound that occurs during the wash cycle and sometimes the rinse cycle. It works perfectly in...
First you take off the front cover of the Machine that is held in place by two clips at the top. then you look at the bottom of the frame assembly that holds the motor. You will find that when the Machine fills with water and clothes the tub drops way down!! and the frame rubs on the bottom pan of the washing Machine. My machine was new!!! and I made two Pads from the old washing machine feet and put them through the two holes in the frame and put a little grease on them and it works like it should GE your engineers should have seen this!!!!! Thank You FROM K.C.Morris God Bless America
Jan 21, 2011 | General Electric Washing Machines
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
During a wash cycle water purs out of the filter
check to make sure that one the drain is not clogged second it my be the water pump going out that pumps the water out to the drain
Nov 28, 2009 | Hoover AAA140 Front Load Washer
Fabric softner still in compartment after wash is completed
take out soap box first and clean,i would say that water valve coil is probably blown though,should read around 3kilohm resitance checked when unplugged hope this helps
May 06, 2009 | General Electric WBVH5100HWW Front Load...
Washer Maytag
the drain hose tear or broken/ clamp detached / need to replace.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
341 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
