Question about Lenovo Computers & Internet
F14 key in lenovo T510 causing error - Lenovo Computers & Internet
Toshiba 207 -f14
Hold down the key's "0", "8" and start the copyer.
After that it will apper (AD) or (ADJ), tst "389" and press the start key.
Then turn off the copyer and turn it on again,that's it.
Jul 03, 2014 | Toshiba e-Studio 207 Copier
Laptop usb printer
You might need a new USB cord for it.
Apr 29, 2013 | IBM Lenovo ThinkPad T510 Notebook
Thinkpad t510 4314 touchpad and mouse stop responding
It shows the fault of USB ports and in my point of view you need to replace with a new motherboard.
Hope it will be helpful.
Good Luck
Aug 19, 2012 | Lenovo ThinkPad T510 4314 - Core i5 520M...
IBM T510 Slow Downloads
If there is no problem with your ISP, then the reason may be one or more problems acting together. The problem nowadays is that it is very difficult and time consuming to monitor and take care of your Lenovo PC. Even experienced users find it hard to perform such tasks on regular basis because you might need to prepare a huge amount of time and energy to deal with each issue separately.
If you want to fix the problems more efficiently, try the Lenovo speed up program, available here: http://www.speeduplenovo.com/
Jan 04, 2012 | IBM Lenovo ThinkPad T510 Notebook
T510 built-in webcam not found
Have you tried updating the device driver for this piece of hardware? This link will take you through to the integrated camera driver download page for the T510. You should be able to download the executable file from this page, once its saved to your default location double click on the file and follow the prompts, you may need to reboot your laptop once the driver installation has completed.
Apr 11, 2011 | Lenovo TP T510 CI5253 156 3GB 320GB DVDR...
F14
Circuit Board Medics can rebuild the CCU to eliminate the F14 error. Find more details to contact them at www.CircuitBoardMedics.com.
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: what does the F14 error code mean?...
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F14 error code, and says Flooding. Help please.
F/14 ERROR CAUSES DUE TO:--EEPROM ErrorThe Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU. If there is an error reading this data, it will cuse this error.
TO RESLVE THIS ERROR MANUALLY TRY THIS BEFORE CALLING ENGINEER :--
Check CCU
May 06, 2009 | Washing Machines
Computers & Internet Logo
26 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
