Unable to uninstall Via HD Audio deck. - Computers & Internet
2 Suggested Answers
map9966
  • 2351 Answers
SOURCE: no audio
You may not have downloads the correct driver software. The Asus P5VD2-VM SE uses the, Realtek Audio Driver V5.10.0.5490 for Windows & HD driver, Realtek High Definition Audio System Software V5.10.0.5366 for Windows. You can download both from Asus by clicking on this link;
http://support.asus.com/download/download.aspx?modelname=P5VD2-VM%20SE&SLanguage=en-us
Please read all of page 1-34 in your P5VD2-VM SE manual to help you setup your audio. You'll need to make a bios change per instruction. If the current software does not uninstall. Enter the bios & disable the setting for HD as shown on page 2-24. Save & exit the bios. The system will auto restart. Try again to uninstall the software, it should uninstall. Create a folder on your desktop & name it HD audio. Download the HD audio software into the HD folder. Do the same for the standard Realtek AC'97 software by creating another folder within the HD folder & naming it, Realtek AC'97. Store V5.10.0.5490 into the Realtek AC'97 software there.
Both files will need to be uncompressed. Enter your bios again & Enable either the [AC'97] or the [HD] setting. Save & exit the bios. Go back into windows device manager. Open the + sign to the left of Sound, audio and game controller. (It will open if it's not already opened).
Rather trying to reinstall by using the sound software's setup.exe file we will do a more direct method of installation.
Right click once on the yellow ! point & left click once on update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find you’re desktop folder named HD & open it. Left click once on the folder named (Depending which you are going to install), Realtek or HD, so it is high-lighted. Than click OK.
Windows will find the correct driver software & install it automatically. Once completed. Close all opened windows & restart you’re system. Test your audio. If you intend to use a mic, you will need to set this up through the Sounds audio devices within the control panel.
If you run into any issue just post your question here.
Good luck nxyz215!
Mike
Posted on Sep 12, 2008
How to balance speakers in VIA HD Audio Deck?
In the VIA interface, click this button, then drag to whatever you want. Took me about 30 mins clicking random buttons to find it. Couldn't find any answers on google so posting it here for others in the same boat.
Beforehand, I couldn't change the balance in the volume mixer because they matched each other's volume - this is a fix for that
Dec 08, 2012 | Computers & Internet
My gigabyte g41 combo doesn't detect front port jack . So i'm having problem in using headphones from when i bought this mother board.I tried both XP & 7 .My front port sounds only when i...
1. check if your front panel is connected to your motherboard at proper port2. check "expert mode" on your via hd audio deck, click "advanced options" and check "redirected headphone" (THIS WILL UNCHECK "INDEPENDENT HEADPHONE") and uncheck "enable front panel jack detection"
this should solve your problem.
Sep 22, 2011 | Gigabyte GA-G41M-Combo Motherboard
Unable to install audio driver Realtak HD
The latest version of realtek would need SP3.. but then uninstall it and reinstall it againg.. it should work. Download the realtek software here... http://www.brothersoft.com/realtek-high-definition-audio-driver-65158.html
thanks for rating Good luck
Jan 13, 2011 | Microsoft Windows XP Professional With...
When using the number pad, hitting the forward slash key gives me popup of the VIA HD Audio Deck. Hitting the minus and plus keys lower and raise the volume of my speakers respectfully. How do I turn the...
This is happening because the forward slash has been assigned as a keyboard shortcut. To fix this problem - Open HD Deck->Info->Hot key and Untick 'Enable Hot Key Function..............
Sep 18, 2010 | Computers & Internet
D945GCNL AUDIO DRIVERS
for this purpose you need to do following :
when you start the computer enter into bios setup.
when you switch on your pc keep on pressing delete button. a menu appers from that go to the motherboard configuration and that menu select audio driver: it must be hd audio deck you should select there realtek audio , now press F10 , press y and then enter. now restart and install the realtek drivers they will be installed without any problem.
Jul 09, 2009 | Computers & Internet
I can capture video into FINAL CUT from VHS deck via ADVC-300, but there is no audio. Is this common?
it should not be. Are you getting audio signal levels on the ADVC-300? I think it may be a connection problem. I always get audio from vhs, even through a camera or hdv deck. Never mind a converter box.
May 21, 2009 | Canopus ADVC-300 A/D Converter Video...
Sir, i need to download an audio driver for my via motherboard.but i cant find it anywhere.an audio codec also support named vinyl deck but i didnt find any downlod link.feeling helpless.thank you.
Something to consider: I did a Google search for "Vinyl Deck Codecs", and it seems vinyl deck to be associated with VIA Technologies, but if I were you I would double check for yourself. I did find this one link, http://www.downloadsource.net/c161/via/ which has a VIA AC97 codec combo drivers pack for several different OS`s, or you could go to Via Technologies, and look at their list of drivers. Note, since I do not know what os you use, type of computer, onboard sound/sounddcard, or even if the via drivers are for sure the ones you need, these hints, are just suggestions/a place to start. It is possible VIA drivers are not even the type you need, but vinyl deck seems to be connected with via. Remember Google is your friend. Good luck, I know the feeling, almost nothing worse than a computer without sound.
Dec 16, 2008 | Audio Players & Recorders
No audio
Good luck nxyz215!
Mike
Sep 11, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Audio
For the HD Audio drive to work properly, you also have to install the Microsoft Device driver for HD Audio. You can download both at the ECS download page here:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=704&DetailName=Driver&MenuID=7&LanID=0
or here:
http://tinyurl.com/22flkf
Feb 11, 2008 | EliteGroup P4M900T-M (V1.0) Motherboard
Computers & Internet Logo
894 people viewed this question
David Payne
David Payne
