Question about Nikon F100 35mm SLR Camera
Custom setting Whenever i take a picture the timer goes on. its not set on timer mode. i think while i was playing with my camera last night it somehow got switched onto a custom mode. idk how to fix it.
  • 37 Answers
This is a known (albeit uncommon) issue with F100's.  Is the wheel on the top left set to the timer setting? If not it may need to be repaired.
Posted on Oct 23, 2007
Why is my manual Mode setting isn't working
The NIGHT SCENE and NIGHT+PORTRAIT scenes are meant to take time exposures of skylines and city streets by leaving the shutter open for several seconds. Therefore, it is necessary to stabilize the camera by bracing it against something solid or - ideally - by using a tripod or camera clamp.
so play around with the shutter speed and bring it to above 100
The procedure is as follows:
  1. Set the camera's Mode Dial to the M (Manual) shooting mode.
  2. Using the Control Dial(big wheel), set the shutter speed to 100.
  3. Holding +/- button and turning the control dail will change focal length.
  4. Play around a bit with this too utill you find right lighting for the image you need.
  5. Remember slower shutter speed needs long time to process the image
May 31, 2014 | Olympus EVOLT E-410 Digital Camera
How to use nikon ML-L3
Set the camera's shooting mode to one of the remote modes. Quick-response remote fires the shutter when you press the button on the remote. Delayed remote gives you two seconds to hide the remote behind your back before firing the shutter.
To set the D90's shooting mode, press the shooting mode button (the overlapping rectangles to the right of the LCD panel on the top of the body) and turn the main command wheel on the back. Quick-response remote shows a picture of the remote control unit, the delayed remote shows that and the clock (the same symbol used for the self-timer).
The remote mode is cleared whenever the camera is turned off. Since monitoring the infrared port consumes battery power, the camera may turn itself off before you take a shot. To prevent this, change custom setting #C5 to something more appropriate.
Oct 11, 2010 | Nikon D90 Digital Camera with 18-105mm...
Whenever I take a picture outside during the day, the pictures come out very bright. I haven't adjusted any settings on it. ideas?
You may have the mode dial set to something like "night pictures"...The ISO may be set too high...the white balance may be on something other than "Auto WB".
Jul 22, 2010 | Casio Exilim EX-S500 Digital Camera
Monitor not starting up -
I think the Power Settings in your Computer needs to be changed. As whenever your computer been IDLE, it goes in a Power Saving Mode.
Adjust your Power Settings from the Control Panel "Power Options" and set them to "Balanced Power Settings" or as per your requirement. There are lot of options their to mention.
Hope your problem will be solved.
Apr 23, 2009 | Computers & Internet
How do I use 360' lens on my Canon G9?
The C1 & C2 settings are for "Custom" settings. You'll most likely want to set your camera either to "P" or "Auto" mode.
To have it delay for 10 seconds and take 3 shots, press the "Menu" button and then scroll down to "Drive Settings". Then, choose the following settings:
Self-Timer: "C" Delay: 10 sec. Shots: 3 shots
Then, press the "Func./Set" key to lock in the change. Next, press the custom timer button on the back of the camera and then choose the "C" timer using the directional keys. Then, press teh "Func.Set" button.
Lastly, set up your camera, press the shutter release, and the timer light should start blinking. 10 seconds later, the camera will take 3 photos in succession.
Hope this helps!
Mar 10, 2009 | Canon PowerShot G9 Digital Camera
Timer Help
I was just playing with this myself...
Hit the "FUNC" button and scroll (if necessary) to "Drive Mode"
Scroll right/left to select 10-second, 2-second, or custom timer setting. If custom, hit the "Set" button then select the timer delay and number of shots to take.
Leave the FUNC display on the screen when you hit the shutter release. It begins counting down when you hit the shutter button, so make sure you've got it pointed where you want it (preferably on a tripod, though any stable surface will do in a pinch).
Nov 22, 2007 | Canon PowerShot A510 Digital Camera
No pictures when in autofocus mode
I was having the same problem with my D40... but I read your post, tried switching the 18-55 lens to manual, then back to auto, and it seems to be working fine now. Hmmmm... think maybe there's a circuitry issue with the lens?
Nov 11, 2007 | Nikon D40x Digital Camera
Type of setting in the night
Try using the night mode on your FZ10, but use a tripod.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
The best situation to use each of the shooting modes
The shooting modes are described as follows: AUTO (Factory default setting) Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. SCENE Scene mode enables you to select one of the following scene shooting modes available in the menu. Landscape + Scene shooting Landscape + Scene shooting is suitable for taking pictures of landscapes and other outdoor scenes. This mode produces clear, sharp pictures with excellent detail, making it ideal for shooting natural scenery. Landscape + Portrait shooting Landscape + Portrait shooting is suitable for taking photos of both your subject and the background. The picture is taken with the background as well as the subject in the foreground in focus. The camera automatically sets the optimal shooting settings QuickTime Movie Quicktime Movie mode lets you record movies. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. My Mode Enables you to make settings manually and register them in the mode dial's mode so you can call up your own shooting mode whenever you want. Program shooting (P) Program shooting allows you to shoot using an aperture and shutter speed that the camera sets. You can set the flash, white balance, or other functions manually. Aperture priority shooting (A) Aperture priority shooting allows you to set the aperture manually. The camera sets the shutter speed automatically. By decreasing the aperture value (F-number), the camera will focus within a smaller range, producing a picture with a blurred background. Increasing the value will let the camera focus over a wider range in the forward and backward directions, resulting in a picture in which
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Nikon F100 35mm SLR Camera Logo
55 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Greg Cann
Greg Cann
Are you a Nikon Photography Expert? Answer questions, earn points and help others
