Question about Brother IntelliFax-4100e Fax
Cannot change report settings on brother intellifax 4100e
I have looked at the manual available on line and i am instructed to hit menu 2,4,1 which gets me to transmission verification report setting but I am unable to change the setting. The manual simple says to use the left and right arrows and press select. When i use the arrow keys the options for the reports do not change. For example, right now it is set to off but pressing the left or right arrow does nothing. It will continue to display off no matter what combination of arrow or select button i use. Please advise. Thank you.
  • knuss Apr 23, 2009
    The problem is when i try to use the arrow keys to change the setting from what it is already set to nothing happens. The arrows as well as the set key seem to do nothing.
    Sergeant:
  • 329 Answers
Remember when you make a setting change on the Brothers you have to hit set to imbed it in the machine. Then exit from the setting menu. Hope this helps..
Posted on Apr 23, 2009
2" black band prints on right-side of every page
print a report, any report, from your control panel. if it looks good and your band is only on copies and transmitted faxes, that would be your Contact Image Sensor going bad. its located under your document feeder and looks like a sinny piece of glass that runs left to right.
hth,
razors
Nov 14, 2011 | Brother IntelliFax-4100e Fax
NG Codes poor line quality 4100 E Intellifax by Brother
To check your line quality is very simple. Unplug the fax from the telephone line and substitute it with a normal single line telephone. Make an incoming and outgoing call. if you hear any echo or crackle on the line when you are being quiet, then you have a noisy line and you should report it to your telephone company to have the line cleaned. If it is quiet then the problem lays with the fax. There are ways around the problem in the software of the machine but its quite complicated and best left to a trained brother engineer.
Sep 08, 2011 | Brother IntelliFAX 4100 Laser Fax
Need maintenace codes for brother 4100e fax
Power off the printer for 15 minutes and power back on again. If that fixes the problem then OK.
If not then go into maintenance mode -
Press and hold the menu/set key while turning on the machine. Wait until it comes completely up before releasing. It should say Maintenance in the display.
If not press function,*,2,8,6,4 within two seconds. It should say maintenance in the display. Or on some machines Menu,*,2,8,6,4 within 2 seconds.
Once you get it into maintenance hit 91 to do a parameter reset and than 99 to get out of maintenance.
You reset all Brother fax machines the same way. Press function, *, 2,8,6,4 all within 2 seconds to place the machine into the maintanence mode. Press 0,1 to perform a parameter reset. this will restore the machine to factory default settings. press 9,9 to exit maint mode.
Procedure is:
1) Unplug machine.
2) Hold down menu key. Plug in machine.
3) Release menu key.
4) Enter 91
5) Enter 99
6) Machine will warm up.
7) Press Reports key, then 1. This will test if the machine can
print.
http://www.brother-usa.com/manuals/default.aspx?PGID=2&R3ModelID=PPF4100
Above link is for the user & setup manuals. The codes are in there.
Apr 05, 2010 | Brother IntelliFax-4100e Fax
IntelliFax-4100e
go into menu, arrow over until you see 2. Fax hit set, then arrow until you see 1. one-touch speed dial, then hit set. touch the one-touch button you want to change, then the number 1 to change it, it will display the number, hit clear to delete it then dial the new number hit set and you're done.
Feb 11, 2010 | Brother IntelliFax-4100e Fax
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
We have a Brother Intellifax 4100e, business class laserfax, superg3 fax machine in our office. When the fax machine goes into sleep mode, we can't get it to come out of sleep mode unless we unplug it and...
Try changing the sleep mode settings. Sometimes it's set too long or too short. You can try the perimeter reset as well. The instructions I have for that is as follows:
hit the menu button and numbers *2864 (star before the four numbers)
then hit 91(set) wait a few seconds for the maintenance screen to return
then hit 99(set) when it beeps saying completed that could fix your problem.
Hope this helps.
Intellifax 4100e is not printing faxes says printing online? Or it stops in the middle of a fax and says same.
try parameter reset function (this will change some settings back to default)
hit these keys all within 2 seconds!!!
function (or menu) * 2 8 6 4
should say maint.mode: then hit
"9 1 set" and then "9 9 set" That will usually clear out any brainfarts in the system. This also works for code 77 errors (9 9 set is the actual parameter reset)
Oct 13, 2009 | Brother IntelliFax-4100e Fax
Confirmation Printout
Yes go into reports on the operation menu. use the arrows to get where you want and confirm by hitting set.
Nov 13, 2007 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Logo
245 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
