Question about De'Longhi NESCAFe Dolce Gusto Piccolo Single-serve Beverage Maker - Make Coffees
Hi, I need buy an mainboard to my dolce gusto piccolo, (type 9744.12) where can I buy (preferentially in NY or Huston)? Thanks a lot (barbosafilho@msn.com)
Hi I have a 24i worcester boiler I have drained the heating to do some work but I need the hot water to still work.I spoke to Bosch and they said I need to put a loop in.I am not a plumber but can get
Hi Steve, I am not a plumber but have done a lot of DIY on my own heating system with Worcester Bosch combi boiler! I believe that you can have the hot water on without the heating system filled, just turn all the settings as for summer use and the thermostat right down so the heating is forced to stay off!
Nov 07, 2014 | Water Heaters
Need repair and diagnosis
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#no-error
Fix any tankless problem quickly yourself today for $380... and install tank-type heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Don't buy tankless... don't buy Rheem products... seriously now.
Gene
h
Jan 23, 2014 | Rheem Tankless Water Heater RTG-74XN-1,...
My family is moving in...how do i increase hot water availability?
large water heater, turn p the themo stat to a higher setting ( watch for burns with young childern and older folks)
or the best install a tempering valve. this valve mixs hot water with cold water before it goes into the building.
Again if you have young ones or old people they can burn faster than any other group.the best is a larger heater for the DIY person.
Thanks Tom
Sep 13, 2011 | Rheem Water Heaters
When I turn on the hot water, I get a milky color of hot water.
Hi this is not a problem with any equipment you are using its just a case of you living in a hard water area, their are filters you can buy but can be expensive to maintain, as the cold water feed is the same as the hot water feed then it may be worth getting a filter fitted to the cold tap as this is the water you will be drinking you can either buy one that fits on the tap or you can buy a brita free standing filter that you just keep filling up with water and use it when you need to.
Their is no problem with the water and it wont harm you and if you say run a bath or fill the sink up with hot water and it looks milky just wait 5 minutes then it should be perfectly clear.
You mainly get this type of hard water when you live near the coast, it can upset your stomach if your not used to this water so boiling it before drinking will give you chance to get your body use to the different water conditions.
Mar 19, 2010 | Water Heaters
How do i refill ny worcester junior 24i combi boiler? as i cannot get the pilot light to light
Two types dependent on age
Early - in the mains water inlet pipe there should be a service valve/tap which when turned on will refill [it is close to or part of the fill loop - a metal braided flexible pipe
Later - underneath there is a hole for a plastic tap [supplied with boiler] to be inserted [usually just right of center] Insert and turn 90 degrees then close to it another small knob or 2nd tap which when turned [same action as a basin tap] will refill. If the first tap is not inserted properly water will drip out past its seals
For both Refill to about 1.5 - 2 bar and turn off
For the later as above but also remove the 1st tap
Mar 14, 2010 | Water Heaters
Broken toilet lid
Sophie; What you can do is chk with Lowes or homedepot. I did the same thing more than once and ended up buying the whole tank. Try to order it and bring the part no. with yo. Try to get the phone no. of the manufacturer, They may ship you one or do a search on the net by typing in the mfg and part no. Good Luck.
Nov 17, 2009 | Water Heaters
Instruction manual for ge smart water filter
Here is the website that you can get your users manual. You will need the model #. Pls rate ny answer
Kurt
http://www.geappliances.com/service_and_support/literature/
Apr 19, 2009 | General Electric GE SmartWater Household...
Slow leak drips from bottom of 4 year old model
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Apr 07, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Valliant turbomax manual
hi ian
most boiler manufacturers now days have downloadable manuals on there web sites.
just type in "vailant boilers" and flix through until you find the correct page. if they haven't a download you can request a copy on the "contact us" page .
i hope this has been some use
Jan 23, 2009 | Water Heaters
De'Longhi NESCAFe Dolce Gusto Piccolo Single-serve Beverage Maker - Make Coffees Logo
74 people viewed this question
Top De'Longhi Water Heaters Experts
Donni Steen
Gil Shultz
Are you a De'Longhi Water Heater Expert? Answer questions, earn points and help others
