Question about De'Longhi Dolce gusto Piccolo Single Serve Coffee Maker"
Hi, I need buy an mainboard to my dolce gusto piccolo, where can I buy (preferentially in NY or Huston)? Thanks a lot ( barbosafilho@msn.com)
My light when on its a yellowy colour it used to light green
KINDLY DO DESCALING BUT IF YOU DO YOU HAVE PRESS THE POWER BOTTOM FOR 5 SECONDS AND IT WILL BLINK YELLOW OR ORENGE ONLY THEN YOU CAN DO DESCALEING THE LIGHT WILL GO BACK TO GREEN BUT ONLY AFTER DESCALING
Apr 06, 2015 | De'Longhi EDG200T Nescafe Dolce Gusto...
Why does my flashing red light turn to orange and not green
HI THIS IS BECOUES YOU ARE DUE TO DO DESCALE .DO DESCALE ONLY WHEN YOU PRESS THE POWER BOTTOM FOR 5 SECONDS TO GET THE MACHIEN INTO DESCALING MODE .SEE THAT YOU GET DESCALING FOR DOLCE GUSTO ONLY IN SIDE YOU HAVE AL THE HALPE YOU NEED
Mar 27, 2015 | De'Longhi EDG200T Nescafe Dolce Gusto...
I plugged my new dolce gusto picolo in for the first time yesterday to do the first clean through of water but no water is coming out
This is normal you have an air lock all most all new machens do that fill the water tank and only run water fro the cold side don't use the hot run water for 5seconds at a time it should the job
Dec 26, 2014 | De'Longhi EDG200T Nescafe Dolce Gusto...
Why does red light keeps flashing on dolce gusto mini me ?
In my case it was a minor detail: The capsule holder tray has a small magnet on the top right side, you can feel a light pull when you are inserting it in the machine. This magnet became dislodged from the capsule holder, and the machine won't operate and will give you a continuous blinking red light if the magnet is not in place; I found it when emptying a small bin where I put the used capsules. You just have to put it back in place with two drops of glue, or if you can't find it, just order a new capsule holder.
The picture shows the underside of the capsule holder and the magnet next to the slot it came from.
Sep 02, 2014 | De'Longhi EDG200T Nescafe Dolce Gusto...
Green light will not come on. red light continues flashing
I have experience in Dolce Gusto melody 3. I think that means that the machine warms up the heater. If it continues giving red flasher, i expect that no electricity reaches to the heater or there is something wrong with the heater sensor. In my machine there is Triac (BTB08-600CW) that drives the heater. Please check and show us what is happen.
Dec 30, 2013 | De'Longhi EDG200T Nescafe Dolce Gusto...
Red light flashing does not turn to green on dolce gusto piccolo
Same thing just happened to my Dolce Gusto Piccolo. It was off for 2-3 weeks, and after turning on, the light just kept blinking red forever. I tried pulling out water reservoir and putting it back repeatedly for a few dozen times (saw somewhere that air should be pumped out of the system), but It didn't help. Then I plugged out the power cord from the wall socket (while the machine was on), and plugged it back after a few seconds. Turned the Piccolo on, and it worked (blinked red shortly and turned green). Maybe it has something to do with induced current. And maybe pulling the water reservoir actually helped :)
Sep 20, 2013 | Coffee Makers & Espresso Machines
My brand new nescafe dolce gusto does not work. there is no water coming out.
If you're getting a "no water" error message then you need to "prime" the machine by either:
1. Fulling the tank with water and leave it in the machine for 2 hours at least.
2. Re-seat the water tank about 70-80 times to get the bubbles out and the water flowing.
Dec 30, 2011 | Coffee Makers & Espresso Machines
De'Longhi Dolce gusto Piccolo Single Serve Coffee Maker" Logo
27 people viewed this question
Top De'Longhi Coffee Makers & Espresso Machines Experts
De Brewerz
De Brewerz
Level 1 Expert
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a De'Longhi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
