Washer won't spin out water from tub. Sounds like there is a brick in the tub too when running. The pump is fine as I just replaced that and checked to see water draining as normal. I took back off and saw belt was slipping and squeaking when it rubbed on back of tub. Inside the cabinet there is uniform line of dark deposit of dirt on walls to right and left of belt. Not sure if this is fragments of the belt sticking to wall or grease from behind pulley attached to the tub this is a front loading Kenmore model 41740042990
  • 3 more comments
  • kothstein2 Apr 23, 2009
    The pump is an electric only pump with no pulley on it and is working. The only belt is from the motor to the rear of pulley wheel behind the tub to spin that.
    also the pulley behind the tub seems to be spinning okay
  • kothstein2 Apr 24, 2009
    sorry I didn't get back sooner. had some family biz to attend to. Anyway I am leaning toward the bearing being the problem as there is the squeaking noise and I believe I wrongly attributed that to the belt rubbing on back of the tub encasement. Also there is the dirty sort of greasy deposits on inner wall of the washing machine that line up with the pulley and belt. I'm guessing that has been slowly coming out and getting flung against the sides. I'll tear it all apart again and pop off the pulley wheel from the back of the tub. probably need a gear puller. Nothing like a good excuse to buy a new tool
    Well I may need your washing machine. LOL. I was looking at the Sears website for the part and it shows the bearing isn't a stand alone part but part of the tub's $170 rear shell assembly. So for the price of the that and pain in the neck of replacing all of that it would make more sense to buy a new washing machine. Additionaly sucks because I just repalced a defective pump in it a few days ago which was due to an accumulation of my son's guitar picks. Oh well. win a few, lose a few.
    This may be good to know for others if this problem pops up again elsewhere.
    Also thanks for the input. I'm generally pretty handy but it's nice to brainstorm with others for a solution if it looks like there is a multitude of possible issues. This is a pretty neat site for that
  • Washing Mach... Master
  • 3,866 Answers
Check the pump!! the pump is usually not working or it is plugged up with some soaps it will do this. The belts are another sign of wear check the pump first then we can move on to the belts in that manner.
If you foundthis information useful rate it Fixya. If not and you need another advice click one below fixya.
Rulds2008
Posted on Apr 25, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Apr 25, 2009
    if the pump is working then there is a blockage take the pump out and l@@K you cannot tell by just hearing it
  • Grand Canyon Tech
    Thanks we try and we hope it Fixya if it dont but it did help and you don't mind letting a few $ go to the expert put fixya as a rating. This dont mean we get a whole lot of money but it keeps us going and helping more people out along the way. You satisfacton is garanteed and we do hope you come back. Thank You for using Fixya I'll be looking forward to your rating.
  • 3,037 Answers
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff and you should replace it. If the pump belt is broken or looks quite worn, replace i too--but be sure to check the pump pulley before you change the belt. Let me know if you need anything else. If the pulley isn't frozen, let me know but that sounds like the problem as long as the motor spins and the belt moves.
Benjamin
Posted on Apr 23, 2009
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 24, 2009
    Verify that the drive pulley nut is locked down good and tight. If it's
    not, the pulley wobbles and can throw the belt and cause it to rub on the tub and can cause other major damage
    to the tub shaft and seals. If the pulley spins straight then you probably need a bearing. Let me know what you find.
    Benjamin
  • Benjamin Patri
    Sounds good, I was assuming that you had marks from the belt rubbing on the machine. Let me know how this goes and if you need anything else.
  • Benjamin Patri
    Benjamin Patri Apr 25, 2009
    No problem lease rate this solution as Fixya once you are satisfied and don't have any additional questions.
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
Maytag navigator washer not draining all the water out
Hello there and thank you for choosing fixya
Here are some things for you to check out
Please read fully this covers a couple of different brands but it is all the same things to check ok?
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jun 23, 2011 | Maytag Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Slow spin, water under the front of my washer
Good Luck!!
Sep 12, 2009 | Maytag PAV2300 Top Load Washer
Washer does not seem to drain. There is a rattling noise that sounds as if something is loose in the load.
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle
It won't drain If your washer won't drain, check these:
May 04, 2009 | Kenmore 24422 Top Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
MY MACHINE HAS STOPPED DRAINING
Good Luck!!
Mar 22, 2009 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
